My monitor was working fine all year long. Yesterday when I switched my computer on, the screen showed distorted startup window screen.I immediatly switched the monitor off for one minute. Then switched it on back again and the screen was black and backlit with power switch indicator as green. On top of screen, there is a very thin white line 1mm thick and the rest is black. I checked the screen with other computers, the same problem (back light with blank screen and green power indicator. Please help.
The capacitors in the monitor give out have to see a technician
The capacitors blew up.
I have similar issues. Have moved the transformer module onto my desk top so I can unplug it easily. I don't have to wait, just interrupt the power for a moment and it will reset. It has to be a hardware problem.
I have the same problem. If the computer goes into power save mode for the monitor the VA912b won't come back on. The LED blinks and it makes a repeating "bloop" noise.
I have no solution other then what was stated. Turn it off for several minutes and turn it back on. Sometimes you have to try this repeatedly before it works. (I have two VA912b monitors that I bought at the same time and both are connected to the same pc - this only happens to one of them)
How old is the monitor? Viewsonic has a 1yr warranty on this particular monitor. There is an internal hardware issue with the monitor that will need to be diagnosed by someone with proper testing equipment.
Wow, many people are having this situation. Mine died out about 2-3 months ago. Same problem. need help :[
I have the same problem, using LCD VA912b, almost 1 year old.
The power cord connect to wallet cord (not to the read of mainboard)
the power led sometimes blink, and i can not see any (the lcd is being black). the power led is flashing, on and off, on and off.....
I have to turn off the computer, turn off monitor power cord. wait about 20 minutes, then turn on again, it will work, but if I turn off monitor then turn on, or restart the computer. the power led will blink again :(
Can you help me?
Same it used to work now it powers up but light is green and does not detect PC
