20 Most Recent ViewSonic VX900 19" LCD Monitor Questions & Answers
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
ViewSonic VX900... | Answered on May 30, 2014
Your PC resolution is to high for what it can display.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/chad_70dccdc9090b1a75
ViewSonic VX900... | Answered on Sep 18, 2013
More likely to be bad backlights inverter in this model, need to check the surface mounted fuses on the inverter board. You also need to check the caps to see if it has any bulging top or bottom seals in the 12vdc power supply module also and make sure it is putting out 12vdc.
See my pictures here:
http://s807.photobucket.com/albums/yy352/budm/VIEWSONIC/Viewsonic%20VX900/#!cpZZ1QQtppZZ20
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
ViewSonic VX900... | Answered on Oct 20, 2011
Hi, First check the power cable of the monitor. Check the system ram and power supply also. Because it may happens for System also. Check your power outlet also. If it doesn't solve your problem then you have to repair the PCB of your monitor.
ViewSonic VX900... | Answered on Oct 18, 2011
Download: http://www.viewsonic.com/products/desktop-monitors/va2231wm.htm
You need to set your PC to the native resolution of the monitor, if it is too high, you will get out off range message: native resolution is 1920x1080p @60Hz.
You can read more here about the message:
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
ViewSonic VX900... | Answered on Aug 03, 2011
Please verify the model number since VX900 is just a monitor, it does not have any remote function, http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX900/
ViewSonic VX900... | Answered on Apr 14, 2011
Please try this:
http://www.fixya.com/support/r4554177-viewsonic_monitor_lock_unlock
ViewSonic VX900... | Answered on Apr 07, 2011
http://www.ic2ic.com/search.jsp?sSearchWord=DAP08
ViewSonic VX900... | Answered on Apr 05, 2011
Does this VX900M version use the wallwart power supply or built-in power supply? Does it do the same when used it with another PC? No signal means it is not getting the video signals from your PC. Wenned to verify if it is PC or monitor problem first.
ViewSonic VX900... | Answered on Apr 01, 2011
There are two version of this monitor, one has built-in power supply, another one uses 12vdc adapter.
Adapter:
http://lcdpayless.com/productpage.php?productId=4629
The adapter is REGULATED 12vdc 6a power supply that can handle the load up to 6a, if when is has load on it and the voltage drops down to 2.5vdc, teh it is that the power supply is bad or you have shorted circuits in the monitor. You can test the power supply using 12v car lamp such as #1157 bulb to test your power supply under load.
Caps in the power supply do go bad as you can see in my pictures here:
http://s807.photobucket.com/albums/yy352/budm/Bad%20capacitors/?action=view&current=badcaps2.jpg
ViewSonic VX900... | Answered on Mar 10, 2011
opening the case will most likely void your warranty.
ViewSonic VX900... | Answered on Feb 28, 2011
Monitors don't have replaceable fuses. If its not powering on, then chances are something inside the monitor died(usually because of cheap chinese capacitors) and you will have to try to RMA the monitor with viewsonic, or replace it.
Check all fusible links (such as 0 ohm resistors) and the voltage regulator as well as the rectifier.
You may also have a shorted capacitor, check all electrolytic caps.
ViewSonic VX900... | Answered on Feb 23, 2011
ViewSonic VX900 19" LCD Monitor Logo
93 questions posted
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ViewSonic Computers & Internet
Most Popular Question
lost remote viewsonic 19 vx900 monitor
  • Computers & Internet
