Vacuums Logo
Bill Simpson Posted on Jun 08, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where do you hook the clear hose that is in the compartment with the motor ? Second where the vacuum hose connects to the bag it keeps cutting in and out of power. I replaced the female cord to motor and still cuts out."no suction "
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Vacuums Master 102,366 Answers
  • Posted on Jun 08, 2013
Vacuums Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10444631
Points
622693
Would you care to tell us the make and model of the vacuum you're asking about?
2helpful
Vacuum goes on for a few seconds then shuts itself off when I go to start again it goes for a few seconds then stops new bag in vacuum can I fix this problem Donna
First, turn dial on top of vacuum counter-clockwise so the smallest dot lines up with the arrow. See if it stays on. If not, detach hose and turn vacuum on. Place palm of hand over intake. If it turns off, it's possible that the tubes connecting to the CVA are clogged and simply need cleaned. This is most often caused by using "made to fit" Electrolux bags. Dust is sucked through the bags and into the motor compartment of the machine. All interior parts get covered in dust and need to be cleaned. If this is the cause, the vacuum is best cleaned and repaired at an authorized Aerus Electrolux store. If the vacuum shuts off, or won't turn on before placing hand over the intake, it's probable the control valve assembly is bad and needs replaced.
Another cause is an overheated motor due to clogged screen at back of bag well, full or clogged bag, dirty afterfilter, bad wiring/connections, clogged hose, clogged power head, or bad motor. It depends largely on the type and model of cleaner. Clogged wands are also a possibility, but unlikely.
Check and clean screen at back of bag well.
Replace bag. Make sure it's a genuine Electrolux bag made by Home Solutions.
Check and replace afterfilter if necessary. These should be replaced after every six bags.
Broken and worn wiring connections are often found in the hose ends due to abuse and normal wear and tear. You can check the continuity of the hose using a continuity tester or multi-tester. If a multi-tester, turn dial to one of the Ohm settings. Place one probe into one of the terminals on the end of the hose. This will be referred to as T1. Touch the other probe to each of the terminals/connections on the other end of the hose. These will be T3 and T4. One of them should read zero, the other should read infinity. Repeat this with the other terminal, which will be T2.
Drop a marble in one end of hose and let it roll through. If it doesn't roll through, the hose is clogged and needs to be cleared. Plug hose into the exhaust port of the vacuum, place other end in the in port. Turn vacuum on. This provides a blowing and sucking action which should clear the hose.
Detach hose from power nozzle (PN). Drop a marble into the wand end of PN. If it rolls through, it's clear. If not, there's probably a clog behind the brush where the intake opening is. You may be able to reach this through wand end with needle nose pliers, or either end with a knitting/crochet needle or a bent coat hanger.
If none of these "fixes" provide the answer to the problem, it should be taken to the nearest Aerus Electrolux store for diagnosis. Repairs or checks involving disassembly of the vacuum should always be done by an authorized Aerus Electrolux service technician.
The store nearest you can be found by following the instructions at the below listed link:
http://www.aerushome.com/storelocator/
My vacuum shows a full bag after 20 seconds of running. Put a clean bag and the same thing happens.
My electrolux2100 every time i turn it on it stays on for about 1 min then the proctection button come on then the machine turns off i wait a second and then it turns back on and does it again what can i...
Mar 29, 2011 • Vacuums
Model 6500sr cuts off at highest control setting even with new bag, what could be causing this problem?
I JUST REPLACED THE MOTOR IN THE MODEL 2100.WHEN I PUSH ON THE START SWITCH, THE PROTECTION LIGHT COMES ON AND THE VACUUM WON'T START.WHAT IS THE PROBLEM?
Things that may cause this.
1helpful
I install a new bag and the bag light comes on and the unit turns off.
Changed bag and filter, filter light keeps coming on, not working
Keeps opening as if the bag is full. HOw do I fix this.
Light keeps coming on saying bag full but its not
Almost certainly there is a blockage in the pipes leading to the bag compartment. This will cause the red light to come on, and it will lead to the motor cutting out from over-heating (as there's not enough air flow to cool it). To test that the light is working correctly, you can unplug the flexible hose from the top of the bag compartment then switch the machine on. The red light should be off, but will come on if you block the hole with your hand. If that test shows the light is working, you need to search for a blockage - which is most likely to be in the flexible hose, but can be in the rigid plastic tube or in the base of the machine (turn it over and look in the little trap-door). Clearing a blockage from the hose can be difficult - you are more likely to be successful if you can devise a way to pull it out rather than trying to push it (as with a broom handle, for example), because pushing may just compact it.
If you need more help, just post a reply here. Good luck!
Motor on the powermate keeps cutting in and out.
If your talking the motor on the beater bar, then chances are either when the beater bar was attached to the hose near where you hold it, it did not lock, and the connection is intermittent, or the cord has an internal break.
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
