Siemens 24 in. SE25T250 Free-Standing Dishwasher Logo
Anonymous Posted on May 31, 2013
Wash pump induction cooling fan siezed up
The fan at the back of the pump seems to have completely siezed up and won't rotate if I try to move it. There is lots of limescale build-up around the pump. Is there a way to treat this problem?
Bill Boyd
Level 3:
Top Expert:
  • Siemens Master 53,816 Answers
  • Posted on May 31, 2013
Bill Boyd
Siemens Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11950870
Points
172802
The fan is connected to the armature of the motor and if it will not move then the motor is seized. Possible because the seal in the pump has failed and water has rusted the armature to the fields of the motor. Suggest you consider a new pump unit.
1helpful
Kenmore front loader stopped washing, or spinning
Is it induction or electronic motor,,,,if its electronic it may be carbon brushes,,,if its induction it may be capacitor
I have a simplicity 6216 mower. When the blades are engaged they back and forth between being fully engaged and losoing power to where they stop completely even though they are engaged.
It seems one of the idler pulleys have siezed up, or perhaps one of the spindles. Un-tension the belt, and try to rotate all of the pulleys by hand to see if any have siezed up or are binding, as those will heat up under operation and stop, but may rotate stiffly when rotated cold, by hand.
Jun 09, 2013 • Garden
My pulley won't move
Does the inner drum move? If not the drum bearings have probably siezed and will need replacing.
1helpful
1helpful
Mercury Outboard 25 HP 1993 Model
If it would not move (rotate) you had a pump failure. A bad pump will often pump enough to go fast but nothing at idle so will quickly sieze.
Aug 17, 2012 • Boating
3helpful
3answers
I have a 2000 lincoln Ls V8 3.9.. The coolant boils, i relpaced the water pump as well as the thermostat. What causes the coolant to boil??
1st, test the water pump and make sure with the belt off, that it turns freely now that you've installed it. Sometimes the impeller is not pressed on completely, and these don't turn properly.
Maybe you did this but just in case:
Always free spin anything installed , IE: water pump, oil pumps, alternator, generators, camshafts, crankshafts, etc., before moving to the next step.
2nd. Verify the belt installation. With today's serpentine belts, a wrong turn may cause the pump to run backwards, but seem correct. There should be a specific diagram under the hood or on the fender.
3rd. If the Belt's OK, Pump's OK, and you have properly installed the new Thermostat. (I have seen them installed upside down and they won't work that way.) If you filled it properly, making sure it was 100% full, then you may be dealing with a blown head gasket, cracked head, or a cracked cylinder wall.
I hope this helps & good luck!
2answers
My kenmore elite dishwasher 665.17053400 motor sounds like its seized. The machine fills and drains ok but won't do a wash cycle. Moter makes a buzzing noize.
This might help you - this type pump assembly doesn't seem to be a serviceable unit - just replaceable.
http://www.youtube.com/watch?v=vNQvDqzMZV4
When I start any program on my Miele Novotronic W820, the machine fills with water and drum starts to turn but after a short time the main wash light flashes on and off. I've tried clearing the program,...
you may find that the water pump is not operating properly as the first fill of water is normally pumpt out first before the wash fill is started unplug the machine and take the back panel off and locate the water pump and check if you can move the cooling fan at the rear of the pump freely if not the take the water outlet pipe off and remove whatever is stopping the rotation of the pump replace all parts and run the machine to see if the fault has been found and cleared eric
3helpful
2answers
Top Siemens Dishwashers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
