SOURCE: LED light of CD ROM blinking problem
hi may change that cable which connect the main board and cd rom !1 this might resolve ur problem
SOURCE: Pavillion dv2025nr Blank Screen, but all LEDs on.
VGA card problem..that's what tech told me & changed it 3 times...but still laptop goes off.(exactly like u described)...they finally said need new motherboard??? so VGA will not do this again!!!! I don't know, If I change motherboard...will this happen again...is it worth it??? My pavillion dv 2000 is only 1.5 years old..was expensive??/
SOURCE: Acer 4520 Dead, Blank screen , No response...
It sounds like something on the motherboard has possibly shorted out. That can range from the CPU to RAM to the DVD. If it's still under warranty I would suggest sending it in for repair.
If you do send it in, please let them know to backup your harddrive if they have to reformat and restore it for any reason. Your important files are still there and safe.
SOURCE: My Acer make Laptop model:
1.
Take the battery out of the laptop & try to turn on the laptop
using power adapter only. If the computer turns on, then the battery is
defective & needs to be replaced.
2. Make sure the power adapter
is not defective. Test the output voltage of the power adapter using a
voltmeter. Compare the voltmeter reading to the nominal value written on
the adapter or the laptop.
3. If you have another processor which is
compatible with your laptop's model, try swapping processors & test
to see if the laptop will work.
4. The power button could be bad.
5. The motherboard could be defective & needs to be replaced
