Cars & Trucks Logo
Anonymous Posted on May 25, 2013
Why won't my 2012 Suzuki Grand Vitara start?
It has no power whatsoever. Tried jumping, didn't work. Checked the main power fuse and it is good. Any ideas?
_-__-___-_
Level 3:
  • Suzuki Master 20,706 Answers
  • Posted on Jun 04, 2013
_-__-___-_
Suzuki Master
Level 3:
Answers
20706
Questions
Helped
6804906
Points
57965
Ill answer for NO ELECTRICAL POWER :
sure and is easy with any DMM meter, got one? any $20 DMM.
my guess;1
engine will not crank
dash lamps out.
head lights out. dead.
post systems of electrical system , all parts that work and those that dont work, and problem is easy.
cleaned battery terminals.
tried borrowed battery that reads, 12.6vdc ? (charged is 12.6)
2012 that is in warranty car.... ?
my guess on 2012
jumping a car, that is battery jump starting.
a battery can short, and no jump start on earth will start shorted battery in car. but does lay down some big sparks, or burns up cheap walmart cables.
if the car will not crank, say just that, my starter motor will not crank
jump started from live running other car.
if true then make sure headlights work , if they dont work fix that first.
HL must always work, even keys in pocket.
best is to put a fully charged battery in the car, jump starting can cause
surges that can damage sensitive electronic$$$, do jumps as a desperate measure,
with a charged battery,
1: Head lights work, no fix that , use voltmeter
2: cranks robustly.
no , wiggle shifter lever, (on A/T cars the park switch blocks cranking) On M/T the clutch blocks cranking.
with any dMM
measure battery voltage before crank and during.
12.6v good. reseted.
cranking.
0 to 10v bad (weak battery or shorted starter motor)
11 and above good. and must crank, if not , starter is bad.
to prove starter is bad, check voltage at starter solenoid coil wire lug.
it must be at 11v cranking , below 8v it chatters, and fails.
if at 0v cranking this lug that means the Key start line is failing.
A/T switch not closes, or bad ignition switch.
5 Related Answers
Anonymous
  • 497 Answers
  • Posted on Jul 15, 2008
SOURCE: suzuki grand vitara 2.0 TDI
check ignition system, clean fuel system, check all sensors
hope this helps
Thanks for using Fixya
Anonymous
  • Posted on Sep 21, 2008
SOURCE: 1999 suzuki grand vitara
G8D711S is not alarm system. This is Daytime Running Light module. You can pull out the connector, your front lights won't work when an engine start.
My GV 2002 has a Autostart AS1203 alarm system. There is a description on Internet.
Anonymous
  • Posted on Sep 27, 2009
SOURCE: Where is the fuse box located on a 2007 Suzuki
open the front cover
its locted at the right side close to the wing
its abalck or brown plastic cover you
need to open it in order to see the fuses
Anonymous
  • Posted on Oct 15, 2009
SOURCE: suzuki grand vitara 2000 tail lights not working
Check the fuse for tail light
Anonymous
  • 20 Answers
  • Posted on Jan 23, 2010
SOURCE: can't find the fuse box under the driver's side dash on my 2000 suzuki grand vitara. my radio/clock not working and dome light does not come on when the driver's side door is opened.
Its below the Dashboard, on the left side of your knee. You have to use a torch & locate it from under the Dashboard, Its roughly near to the Clutch Pedal.
Here, it looks like this: (The Black one is the Fuse box) ba18901.jpg
2004 Suzuki Grand Vitara. The speedo isn't working and my radio doesn't work.
Question edited for clarity and add maker.
Question moved to model category.
There are no fuses covering those because they are computer functions
https://www.google.com/search?q=2004+suzuki+grand+vitara+fuse+box+diagram
Both are functions of the ECM and the BCM computer via sensors.
https://www.google.com/search?q=mobile+auto+electrician+near+me
https://www.google.com/search?q=2004+Suzuki+Grand+Vitara.+radio+isn%27t+working
The most common reasons a Suzuki Grand Vitara speedometer isn't working are the vehicle speed sensor (VSS), a faulty speedometer, or an electrical issue.
Suzuki Grand Vitara Speedometer Is Not Working
2006 Suzuki Grand Vitara. My dash lights and my headlights won't work?
Question edited for clarity, add maker.
Question moved to make model category.
Check the fuses and relays.
Fuse Box Diagram Suzuki Grand Vitara (JT; 2005-2015)
https://fuse-box.info > suzuki > suzuki-grand-vitara-jt-2...
In this article, you will find fuse box diagrams of Suzuki Grand Vitara 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012, 2013, 2014 and 2015, get information ...
2005 Grand Vitara taillights not working?
Check fuse Q. Check the contacts in the bulbs. check the operation of the bulbs with a couple of lengths of wire and the battery, or test continuity with a meter. Check the contacts in the connector. Check the earths on the back panel. Check for broken or damages wires.
It is located under the instrument panel (on the driver's side). The location of the fuses in the passenger compartment: Suzuki Grand Vitara (2005-.
More here
https://www.google.com/search?q=2005+suzuki+grand+vitara+tail+lights+not+working
2009 Suzuki Grand Vitara 2.0L with petrol engine.
Possibly a bad connection on the Cam Sensor. Clean the two sides of the plug with electrical switch cleaner.
https://www.google.com/search?q=2009+suzuki+grand+vitara+2.0+rev+counter+jumping
Sorry for the delay in answering :>D
Where is the relay box?
Fuses and relay Suzuki Grand Vitara 2005-2014
For the Suzuki Grand Vitara 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012, 2013, 2014 model year. Fuse box location. The fuse box is located under the driver's side of the dashboard.
Fuse box diagram Suzuki Grand Vitara
How do I remove the main fuse in an 02 Suzuki Grand Vitari XL7?
Sparks do fly, the last connection on the cables is ground
to a metal , on engine not battery,
this will make a small, spark. all do, that. done right.
but if done backwards, a huge spark with the 2 batteries bucking each other, and damage will happen.!
yes you may blow the main fuses,
my guess you blew the 80amp fuse in the main fuse box under hood.
did you put the new battery in correctly Plus to PLUS
and NEG to NEG lugs, if not, BOOM AGAIN.
open hood,
fuse 1, if it ok, then the others fuse to the right blew.
when fuse 1 blows, all things die. zero power to anything in car
including head lights, (head lights are always the first check)
18helpful
2answers
2000 suzuki grand vitara 4 wheel drive will not engage
2000 Suzuki Grand Vitara rear Wheel Drive working but 4wheel
is not working, dash 4wheel sign light not working
2helpful
I need diagram ecm wiring for suzyki grand vitara
visit here for diagram wiring suzyki grand vitara
http://www.wiringdiagrams21.com/2009/05/28/2007-suzuki-grand-vitara-main-fuse-box-diagram-and-table
or here more complette:
http://pdftown.com/Suzuki-Grand-Vitara-Service-Manual.html
Power out let and radio blown fuse. how to reset "self rest fuse"
copy and paste this link in your web browser for the diagram of your fuse box:
http://images.google.com/imgres?imgurl=http://www.wiringdiagrams21.com/wp-content/uploads/2009/05/grand-vitara-main-fuse.png&imgrefurl=http://www.wiringdiagrams21.com/2009/05/28/2007-suzuki-grand-vitara-main-fuse-box-diagram-and-table&usg=__cvmvEf_Hfx5xJUv4f9f5EIVWG1o=&h=252&w=276&sz=8&hl=en&start=17&um=1&tbnid=bpnMaZ4d6GDVjM:&tbnh=104&tbnw=114&prev=/images%3Fq%3D2006%2Bdodge%2Bcaravan%2Bfuses%26hl%3Den%26client%3Dfirefox-a%26rls%3Dorg.mozilla:en-US:official%26hs%3D9nw%26sa%3DN%26um%3D1
Top Suzuki Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Suzuki Expert? Answer questions, earn points and help others
