Interior 20w icandescent lamp has burned out on my FMV156EMA. How do I go about changing out? I do not have manual and on-line manual is only available thru snail mail.
Remove the 3 screws on the vent above the door. Next unplug the oven from the power source.Next you will see a single silver screw above the control panel..remove it and slide the control panel upward and out. This will give you access to the lamp socket...turn it left or right and pull slightly ...you can now unscrew and replace the bulb....It was my exp that the lamp got loose in the socket from slamming the door after about a year, and I only had to tighten the bulb..Hope this solves the problem...Jerry
Hi my name is mark, i found a model close to your model # follow the link and go to page 29 http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0409632.pdf hope this helps. thanks for your question.
