E-Machines eMachines T3830 PC Desktop Logo
Posted on Mar 17, 2009
NO POWER TO THE MOTHER BOARD OF MY EMACHINE
NO POWER ON MY EMACHINE i HAVE REPLACE MY POWER SUPPLY BUT I HAVE 3 WIRES THAT RUN FROM THE FRONT PANEL HDD LED POWER LED AND POWER AND DON'T KNOW WHERE THEY GO TO GET POWER TO THE MOTHER BOARD
gernar
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Mar 17, 2009
gernar
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
2769
Points
25
The Wires goes on the motherboard, check your motherboard manual for reference
  • gernar Mar 17, 2009
    If you find the solution helpful. Thank you for your rating me.
Emachine w5243 power is available. LED lights come on. But computer won't start.
1. You may need another power supply.
2. Your hard drive may have failed or the connector has come loose from the motherboard and or the power supply connection.
3. *********** board has failed.
4. the Cmos battery on the mother board has depleted and needs replacement.
2answers
Emachine T3958 wont turn on
make shure that the 4 wire plug to ther mother board from power supply is plugged in..other wise try a new power supply
1helpful
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
2helpful
I have emachine w3400 not powering . plz help
I found this right on this website, hope it works!
As for the fans, make sure your connections are tight and in the proper sockets.
2helpful
Need help with enachine t2528 wiring power sw wire on mother board
If you open the CPU cabinet you will find the front panel connection pins at opposite right corner to the motherboard IO ports (where we connect all the power,monitor,keyboard,mouse chords) You can easily identify it as below these pins it will be named as P_Sw or P_Bt,Pw_led ,Hdd_led etc
Power supply for Emachine
WhoDoctorK9 is right. You'll need the model number of the pc to pull up any schematics of the board. This is, however, how you solve this problem. Just google your model number and try to find a schematic of the board.
If you can't find the schematic, the board should be marked with some sort of 'pwr' blah blah white lettering. It's hit & miss, but you can find the connection without visual aid by dimensions of the plugs and the obscure little identifiers on the board itself.
Good luck and may the force be with you. :P
2answers
No boot, New PS, Green light on MB lights, No Fans running
Bottom line: Either your power supply or (hopefully not) the mother board has gone bad.
Replace power supply (remove old one), take to local independent computer shop, ask them for new unit. Should be around $50.00. - no more. After reinstall, if still no fans, boot, etc. Replace motherboard or buy a new machine. MB's installed probably will run you around $250.00-ish.
Good luck.
gurutim
Wire came loose on pavilion xe 734 that supplie power to hard dir
First of all these wires don't supply power to HDD. These wires are for indicator LEDs on the front
panel of the cabinet. One wire `power sw' is to switch on the system from the power button on front panel. `power led' wire is of the power led on the front panel. All these wires will be connected to the cluster of pins on one corner of the mother board. If you can see it will be indicated & printed near the cluster of pins on the mbd, that which pair of pins is meant for what connector. Try to correlate the names on connector with the print on the mbd.
Emachine t2542
When you say out, do you mean they are broken, or just disconnected? Most of these computers have a plug on the end of the wires to the front panel and it just plugs into the system board. If you look at the board you'll see where the front panel wires go. Sometimes it's hard to read the small type, but there are labels on the board that tell you what connector does what.
Emachine T4060 power supply
I have to assume you mean
Will the cooling fans run if it is still powered by mother board and disconencted from the mount ,such as processor or chipset ??
Yes it would , but is a very dangerous thing to do ,as it could easily short against anything within the case
Be more specific with your problem maybe someone can help you better
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
