Cannot unlock safety cap the steamer has been emptied and not used for a couple of weeks
SOURCE: Karcher SC 1502 steam cleaner can't get cap off water tank
Dear jrider784,
I solved a problem like this on FIXYA, just a few months ago. I gave this solution. Try to fill the machine from somewhere else. You can do this from the outlet. If you manage to do this, put on the machine. ( now you know that when there is hot water in the machine, the tap goes round free for safety). Now as the water starts to cool down....start trying to see if you can unscrew it. My plan is that with the hot water, the safety will start to work again. If the cap does not release the safety on cooling, then there is no other way but to destroy the cap and replace with a new one. Very important to mention that this job must be done by a qualified technician or some one who knows what he is doing. Working with hot water is very dangerous.
Regards,
Fulltech.
SOURCE: Steamer filler cap is sealed
You need a little more leverage--either a strap type tool or a pair of adjustable width pliers that span the width of the cap. Try running hot water over the cap first which may loosen it enough to remove by hand.
SOURCE: I have just used the karcher steam cleaner and now
i cannot get the cap off my karcher sc1122 even though its cooled down
SOURCE: DE4002 Steam Vacuum: Is there a manual for The Karcher DE4002 steam cle...
Hi There,
Here's a link to the owners manual for your Karcher DE4002.
If you found this information helpful, please be sure to rate the repair helpful, or leave feedback. This is really appreciated.
Owners Manual For Karcher DE4002 Steam Cleaner
SOURCE: need a water tank safety cap for euro- pro
I need a cap which is located on the back of the clean water tank on a Bissell model 1950-3 steam cleaner
