Kodak EasyShare Z712 Digital Camera Logo
A
Anonymous Posted on Nov 05, 2017
Battery Life CRV3
This camera eats up these batteries. It works for a taking pictures but if I don't use for a week or more the battery dies. Is this common in this camera? At $10 a battery it'd be cheaper to use nondigital 35mm film! I just got a rechargable but it only lasted for two test pictues. Sometimes I can't even close camera.
5 Related Answers
Anonymous
  • 215 Answers
  • Posted on May 30, 2006
SOURCE: New Rechargable Batteries Die after A Couple of Pictures
This model is renowned for poor battery life. Some people say using the CRV3 battery lasts a lot longer but my advice is to buy NimH batteries with at least 2600mah. Some Nimh are only 700mah and obviously will last less than a third the time of a 2600. Keeping the use of the LCD to a minimum will increase battery life and using the flash puts a tremendous drain on the batteries so if you can do without the flash switch it off. Combine these tips with a set of 2600mah batteries and I'll guarantee you'll be pleasantly surprised. As a sideline I always have a good laugh when I see an Olympics opening at night or a firework display and all you can see is thousands of flashes going off which the majority only reach about 12 feet maximum and the parade being shot is some 300 feet away. BMW
Anonymous
  • 58 Answers
  • Posted on Feb 13, 2008
SOURCE: EasyShare Z712IS
the camera will work with any brand of lithium but only the KLIC 8000 battery will work as a rechargeable
please look at your getting started guide and check page 1, there's an illustration of the 3 types of batts that will work:
lithium crv3, lithium aa and klic 8000
ni-mh is really not compatible
please check at the bottom of your camera, the three types of batts I mentioned are engraved at the battery door
thank you
Anonymous
  • 5158 Answers
  • Posted on Jan 10, 2009
SOURCE: Kodak Z712IS-batteries die so quickly
you can't really get around the fact that digital cameras create a heavy strain on batteries. rechargables are the only way to go with them. now about the chinese battery. the voltage may be fine but that is not under load (being in the camera during operation) so it's deceptive about the voltage.
Robert
doityo
  • Posted on Apr 29, 2009
SOURCE: Bought the Kodak Klic-8000 battery
Put a small piece of two sided tap in the grove, about 2 x 2 x 1 mm and see it it slides the switch completely, don't remove tap from the outerside.
Anonymous
  • 527 Answers
  • Posted on Aug 05, 2009
SOURCE: my camera eats batteries....no matter what kind I use
Sir,
Please follow these steps....
) You can lower the setting of your digital camera so that the quality of photo is reduced from the typical "standard quality" which comes set on the camera. What you will need to do is go into the options and reduce the quality to "economy" so that the battery expands less energy to take the picture, which will lead to longer batter life.
2) Make sure that you have calibrated your battery before you bring the camera along on your adventure. You can do this by charging your battery fully and then turning on the camera so that it dies. Once this happens you can charge it again and you will find that it will now last a lot longer than it formally did. I have found this to be very useful with all of my digital cameras.
3) In order to get the most out of your battery you should switch the battery in your camera from standard disposable batteries to rechargeable batteries. This is because of the fact that they last 2x as long as expand less to actually take the photo according to the Energizer rechargeable box.
4) You can go into the settings and turn off the flash if you see one when you are taking a picture. This will reduce the amount of energy going out of the camera which means that your battery will not die as fast as it normally would. You will need to select settings and then choose "no" next to the word flash.
5) You can also make your battery last longer by adjusting the settings so that you are not recording audio notes with your pictures. This will drain your battery fast so you should go into your options menu and select audio off. According to my Sanyo instruction booklet this will make your battery last up to an hour longer.
Thanks
Good Luck
I bought my Nikon Coolpix s3100 in the USA one week ago. It is my third Coolpix thought the years and I have been very happy with them. Now I am in Europe, with a plug to change from US to standard EUR....
I don't know where you got your information but, most of it is incorrect. Your camera can use two types of batteries: rechargeable EN-MH1 using the MH-70 battery charger or a non-rechargeable CRV3. The camera cannot be charged with a cord to the camera. Also, new EN-MH1 batteries will discharge quickly for the first few charges and then give good service thereafter.
My Kodak ZD710 Will only let me take about 11 pics and the batteries go dead, I have used the CRV3 battery pack
Welcome to FixYa.
Kodak lithium digital camera battery CRV3 (non-rechargable) approximately can take pictures up to 500 pictures. However, actual life may vary based on the usage.
How to extend your battery life?
1. Use power saving features (using a power saving modes). Limit activites such as reviewing pictures/videos on the LCD.
2. Dirt on the battery contacts can affect battery life. Wipe the contacts with clean,dry cloth before loading the battery in the camera.
3. Battery performance is reduced at temperatures below 41 F(5 degree celcius). When using your camera in cold weather, keep spare batteries warm. Do not discard cold batteries; when they return to room temperature, they may be usable.
Please let me know if you have any questions and if this solution was helpful.
Thank you for using FixYa.
Kodak EasyShare Z612 Shuts down after taking a few pictures.
Question : What batteries can I use in my digital camera, and how long do they last?
Battery life depends on how you use your camera, the type of batteries you select, and how you handle the batteries.
Your camera is compatible with: KODAK Li-Ion Rechargeable Battery KLIC-8000 and KODAK CRV3 Lithium Batteries: A non-rechargeable battery. (so your battery might be in need of a change)
Using Your Camera
Some features, such as reviewing pictures and using the flash, require more power than others. Follow these guidelines to get the best use of your batteries:
  • Limit the time your camera is in Review mode.
  • Limit your use of the flash.
  • Use the LCD Dimmer or Auto Power Off features, if available on your camera.
  • Transfer your pictures to your computer using a compatible power adapter, camera dock, printer dock, or memory card reader.
  • Check that the latest firmware is installed on your camera. See Software, Driver & Firmware Downloads.
Handling Your Batteries
  • Wipe the battery contacts with a clean, dry cloth before loading it in your camera.
  • When using your camera in temperatures below 41° F (5° C), carry spare batteries and keep them warm.
  • Do not discard cold batteries that do not work; they may be usable when they return to room temperature.
  • Do not allow batteries to touch metal objects, including coins. Otherwise, the batteries may short-circuit, discharge energy, become hot, or leak.
How long should a crv3 battery last?
I use crv3 batteries in my Pentax istD. Believe it or not, they last over a year! Keep in mind that the simple act of testing the voltage of a crv3 will shorten its life. Have you tried cleaning the battery contacts in the camera with a cotton swab lightly dampened with rubbing alcohol? Sometimes, an invisible film on the contacts forms and gives a false reading of battery life.
Battery life of kodak easy share is 2 pictures ... if that
Please check what type of batteries are these.
Z1085 will only work with LITHIUM AA's, Lithium CRV3 (you have to make sure it's not Ni-mh crv3) and a rechargeable KLIC 8000 Lithium-ion battery pack (the blue one). It will not work with any other type of rechargeable battery but KLIC 8000. If you're trying to use ni-mh rechargeables, it will really not work.
Camera not operating - cannot take picture
alkaline batteries?
please try lithium crv3 or lithium aa's, it may really do that even with a new set of alkaline aa's
if you're using ni-mh, make sure it's recharged and if it is, and it's still doing the same thing.. note that most ni-mh's life span is 300 charging cycles. if you barely use the rechargeable batteries, they can still deteriorate through time. if the rechargeable batteries are new, or say 6 month's old - that means the cam actually needs a repair
Sony Cyber-shot DSC-H7 Battery Life is Only Hours Now
Can you verify that your charger accessory is working correctly?
9helpful
6answers
Camera keeps turning off
Digital cameras are very Voltage Sensitive. Using Nicad or NiMh batteries will not only , "Not" solve the problems above but will
actually aggravate the above problems for one reason.
Rechargable NiCad or NiMh batteries only produce 1.2 volts fully charged and will only give you 2.4 volts when used in pairs with this camera. This falls below the cameras desired 2.8 - 3.0 voltage requirement and will only result in about 30-40 pictures at most.
This camera requires a constant 2.8 - 3.2 volts to run properly. Kodak won't tell you this !!The camera was designed with Oxy Akaline batteries in mind.New alkalines will produce 3.2 to 3.4 volts in pairs but only for a short period of time.The issue with the Oxy Alkaline batteries is that they simply will not last very long in this camera due to its power requirements.
But there is a really great solution to the problem . You can purchase a CRV3 rechargeable Li-ion battery that fits right into this camera.
You will get a realistic 180-250 photos per charge.The Li-Ion battery maintains a constant 3.0 volts for a very long period of time
and will allow the camera to function the way Kodak originally intended it to and can be recharged. You will find rechargable CRV3 battery kits on ebay or other online battery stores at a very reasonable cost.
You can also use a Lithium Non rechargeable CRV3 battery that will give approx 250-300 photos per battery but you may
find non rechargeable Lithium batteries cost prohibitive.
I use the rechargeable Li-ION Battery exclusively in this camera and it functions perfectly since I switched. I have a pair
of CRV3 Li-Ion batteries so I always have a fully charge CRV3 ready to go.
For reference I was only able to get about 30 pictures with the high capacity 2800 Mah Rechargeable NiMH Batteries I used prior
to using the LI-ION Battery. I get on average about 175 pictures per full charge from the LI-ION Battery.
3answers
Hi Scorps1, You can solve the battery problem by updating the firmware for the camera. You can find it at http://www.kodak.com/go/c340downloads Please let me know if you have any problems, and let me know if it fixes it. Best regards, nightdiver
Samsung Digimax V4 Power Consumption
I had similar symptoms as well until it finally died: 1) First started eating batteries like crazy, especially standard AA and rechargeables. The CRV3 seemed to work a bit longer. 2) One day out of nowhere the autofocus stopped working. I replaced the batteries and it worked again for 10 shots. Then the autofocus stopped working and battery died (with the lens stuck open). Pressing power, the LCD backlight flashes on, the LED in the view finder blinks, and the lens motor makes noise. Then nothing just stuck open. 3) Again new batteries and was able to close lens, take a few pictures and dead again with lens stuck open - same problem in 2. 4) Replaced the batteries a couple times and was able to get a shot or two off, and now its complete stuck open, even with brand new batteries - with same problem in 2 it just won't turn on. I finally sent it to Samsung the week of Christmas. I called Friday 1/7/05 to check and had to leave a voicemail. They called back Monday 1/10/05 to let me know they recieved it and that I should call back Thursday to check its status.
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
