20 Most Recent Samsung Digimax V4 Digital Camera Questions & Answers
Use the USB cable to a PC. The storage should be activated as a couple of drive letters.
Samsung Digimax... | Answered on May 09, 2015
Is the card over 2GB ? This camera will only take cards up to 2GB
Samsung Digimax... | Answered on Jun 03, 2010
Sounds like you used the computer to erase the card. The camera doesn't recognize any actions taken by the computer. 1. Go into the camera menu and find "reset"...follow the on-screen instructions. 2. Insert the card into the camera, find "format" in the menu and follow the directions.
Samsung Digimax... | Answered on Feb 11, 2010
Not compatible on brand new computers made in 2006 and beyond.
Samsung Digimax... | Answered on Nov 24, 2009
Hey, no problem, I did not know what you were saying anyway but Samsung camera, I know. Getting a part would be difficult in US also. I believe our part department has been tracing and pursuing to obtain parts from the Samsung Factory in New Jersey without any success. They may have closed it and assigned the task to a very small supplier. Better to find LCD screen from a broken unit in the internet perhaps in EBAY?? You may have to wait for a broken lens unit with good LCD. Good Luck. For further request, send our company a request email we may have one since we purchase tons of used digital cameras such as your situation. www.camerarepairjapan.com
Samsung Digimax... | Answered on Mar 26, 2009
The processor is fried. This can not be repaired.
Samsung Digimax... | Answered on Jan 17, 2009
Check the CD is there a manual there in multi language in PDF format.
Failing that the Samung website
Samsung Digimax... | Answered on Jul 28, 2008
I had similar symptoms as well until it finally died: 1) First started eating batteries like crazy, especially standard AA and rechargeables. The CRV3 seemed to work a bit longer. 2) One day out of nowhere the autofocus stopped working. I replaced the batteries and it worked again for 10 shots. Then the autofocus stopped working and battery died (with the lens stuck open). Pressing power, the LCD backlight flashes on, the LED in the view finder blinks, and the lens motor makes noise. Then nothing just stuck open. 3) Again new batteries and was able to close lens, take a few pictures and dead again with lens stuck open - same problem in 2. 4) Replaced the batteries a couple times and was able to get a shot or two off, and now its complete stuck open, even with brand new batteries - with same problem in 2 it just won't turn on. I finally sent it to Samsung the week of Christmas. I called Friday 1/7/05 to check and had to leave a voicemail. They called back Monday 1/10/05 to let me know they recieved it and that I should call back Thursday to check its status.
Samsung Digimax... | Answered on Sep 12, 2005
By default, Windows uses a 32bit FAT when formatting which is NOT compatible with most cameras. I'd suggest sticking to using the camera menus for formatting a card, unless the camera can't format one (then, if you must use a PC for formatting, make SURE you select FAT as the File System Type). I'd also recommending formatting again with the camera menus before using a card if you ever do need to format one with a PC. As for your problem with the laptop seeing the card, it could be any number of things. It's more likely related to the USB drivers. Many users report intermittent problems with USB connectivity after upgrading to SP2. A frequent solution that sometimes works is removing all devices drivers related to USB (My Computer, Properties, Hardware, Device Manager). Then, rebooting and letting Windows find and reinstall the drivers again. Sometimes, updating these drivers can work, too. You may also be seeing a conflict between other USB devices and drivers. For example, sometimes HP Printer Monitor software conflicts with USB connectivity to other devices. You may also want to try a different USB Port. If all else fails, consider a Card Reader (they're very inexpensive now -- you can probably pick up a USB 2.0 card reader for around $20.00 locally). With a laptop, you may also want to consider a PCMCIA based reader.
Did you try to copy the files to your computer first then open them? While the SD is in the reader, you should run a chkdsk on the SD drive to make sure there are no lost clusters etc. maybe the file table is corrupted...
This can be a broken shutter cable inside the lens. Toes it still make the "click" (not from the speaker)?
Samsung DigiMax... | Answered on Mar 16, 2015
be sure your lense and autofocus sensors are clean first thing.. then push the take picture button half way and it will autofocus. Pressing hte take picture button fully then will snap the picture.
Samsung DigiMax... | Answered on Jan 03, 2015
If you have a computer, insert it into the card reader,l select it and format with your computer
Samsung DigiMax... | Answered on Dec 28, 2014
The 401 takes MMC and SD cards, 2GB or smaller.
Samsung DigiMax... | Answered on Oct 06, 2014
Samsung Digimax V4 Digital Camera Logo
Popular Tags
16 questions posted
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
View Most Popular
DigiMax Samsung
  • DigiMax Samsung
Most Popular Question
just tried new memory card in samsung
  • Cameras
