Cooktops Logo
Anonymous Posted on May 03, 2013
Turn off child lock - Cooktops
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Master 102,366 Answers
  • Posted on May 03, 2013
Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10444082
Points
622693
What make and model?
What does error code L means on the delonghi cooktop
The L indicates that the child lock feature has been enabled. This ensures that the burners do not function while you clean the cook top and that a child can't turn on any burners.
The procedure depends on your cook top model. For some induction models, to toggle the child lock feature off, press the front right burner zone display and the booster function key (circle with a solid circle inside on the right of the selector zone) simultaneously. Then press the front right burner zone display again until the L disappears from the display.
See page 23 of the manual for the Delonghi DEIND804 available here: https://www.appliancesonline.com.au/public/manuals/Delonghi-DEIND804-Induction-Cooktop-User-Manual.pdf .
For an electric ceramic cooktop DTCH808, to turn off the child lock completely, press the bottom right + in a circle and the - in a circle (in the center surrounded by 4 of the + in a circle areas) simultaneously and then release the keys. Press the - in a circle again. See page 21 of the manual here: https://www.delonghi.com/Global/InstructionManuals/EN/EN-DTCH80B_im.pdf .
I hope this helps. Please add a comment with the model of your Delonghi cook top if these instructions do not apply to your cook top.
Help omega cooktop only displayinG H or L help
Child Lock:
After switching on the control, the child lock function can be activated. To activate the child lock,
simultaneously operate the right and the left of the slider button and then operate the right of the
slider button again. "L" meaning LOCKED will appear in all heater displays and the control can not
be changed. (If a cooking zone is in the hot condition, "L" and "H" will be displayed in alternation.)
The hob will remain in a locked condition until it gets unlocked, even if the control has been
switched off and on.
To deactivate the child lock, first switch on the hob. Simultaneously operate the right and the left of
the slider button and then operate left of slider button again. "L" will disappear in the display and
the hob will be switched off.
U
Jun 25, 2018 • Cooktops
How do i turn off child lock
I expect you have found the solution by now since this post is so old - but for any other that are searching, just push the child lock knob down and turn the knob and it should pop back up, turning the gas back on.
Gaggenau 230-110 steamer - cant take the child lock off!
Hold the child lock button down for 5 to 10 seconds. This should unlock it.
Apr 09, 2009 • Cooktops
ZKT 623 LBV digital hob
hi gud day,all hob is almost the same to use,if touch control ur unit,put ur tumb wer the place sign of child lock & off sign..tnx
Jan 29, 2009 • Cooktops
19helpful
3answers
Aeg hob
It is child lock.
Turn cooker on, press two + at front of oven, this will then take it off for that cooking session.
To turn child lock off switch on hob, and touch - for 5 seconds.
2helpful
2answers
Hob not working
It is child lock.
3helpful
Child lock on for neff t1443
gud day,not all models of ceramic hob have a child lock,check it 1st ur unit if have it,if we have,touch the circle w/sign of key to lock the ceramic for ur child,to unlock touch again.u see the ligth red is on it means the lock is in ON.easy to unlock even ur child by touching the key sign,for ur safety to not use ur unit,unplug the unit if it not use.
24helpful
3answers
Have a baumatic ceramic hob displayin letter 'L'
Got the same problem, and remembered I've kept the manual book
L means locked. I dont know how Ive managed to do this as well
Anyway it says:
Cancelling the key lock
After switching ON the control the child safety feature can be deactivated. Here it is necessary to simultaneously operate the front right cooking-zone-select-key and the MINUS-key and then operate the MINUS-key alone. If all steps hae been carried out in the right order within 10seconds the key lock gets cancelled and the control is OFF. Otherwise the input will be considered incomplete, the control remains locked and switches-OFF after 20 seconds.
After a renewed switching-ON/OFF key all displays show 0", the display dots are blinking and the control is ready for ooking. If a cooking zone is "hot", "H" will be displayed instead of the static 0".
Followed their instructions & still not worked. ,I am still confused and baffled after these instructions........................
Top Cooktops Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Cooktop Expert? Answer questions, earn points and help others
