No start
SOURCE: wiring schematics for 2007 cub cadet lt1045 need
this should help Tim:
http://cubcadet.custhelp.com/app/answers/detail/a_id/1722/~/cub-cadet-technical-service-manuals
SOURCE: i need a wiring diag for a international cub cadet
Here is the wiring dagram for sn's 720000-737624
http://www.cubfaq.com/wiringdiagrams/782a.jpg
Not sure why the problem manifests only when the blades are on.
Battery charging power comes from the white alternator wire on the engine thru the key switch (in run or start position) terminals R to B through the charge indicator and a fuse to a connection on the start solenoid and then to the battery. It does not go through the PTO clutch. The only thing that would make any sense is if there was a chassis wiring harness short that was being made by the position of the mower deck.
Hopefully the diagram will help you find the problem.
Thanks for choosing FixYa,
Kelly
SOURCE: Are there more wiring schematics for a 1450 Cub Cadet Garden Tractor
I have 2 or 3, if I show you is not right. Come back, show a difference one.
SOURCE: Cub Cadet 2150 ignition problems. Need a wiring diagram to source problem.
don't have a diagram but i would check the safety switches jump them while looking for the bad one with a paper clip
My name is Dane and I am going to try to help you solve your problem. Here is a link to where you can find your 3000 series manual. The wiring schematics start in chapter 13.
http://www.mymowerparts.com/pdf/Cub_Cadet/Cub_Cadet_Service_and_Repair_Manuals/
I hope I've helped. If you found this information useful, please leave me some THUMBS UP as deserved. Thank you! Dane
