Question about Cub Cadet Op's Manual Model Lt1042 Lt1045 Lt1046 Lt1050
Wiring schematics for 2007 cub cadet lt1045 need to know where wires hook up on ignition switch wires on mower were pulled from block and knew wiring block has different colored wiring
Posted by outdoorkid69 on
Tim Whalen
  • 3,074 Answers
This should help Tim:
http://cubcadet.custhelp.com/app/answers/detail/a_id/1722/~/cub-cadet-technical-service-manuals
Posted on Jun 04, 2011
I need to know what wires hook up to my coil in a 1650 cub cadet
TRY here http://www.bing.com/videos/search?q=wires+hook+up+to+coil+in+a+1650+cub+cadet&qpvt=wires+hook+up+to++coil+in+a+1650+cub+cadet&FORM=VDRE
Dec 23, 2016 | Cub Cadet Garden
2007 LT1045. Where can I get a wiring diagram?
Parts Manual/wiring diagram can be acquired from Cub Cadet at their website.
Aug 04, 2015 | Cub Cadet Garden
Cub cadet LT1045 starter solenoid: can 4 prong replace 3 prong?
Yes you can. The small wire from the key switch goes to the prong closest to the power wire from the battery.
Dec 12, 2012 | Garden
PTO WONT WORK on myCub cadet ride on mower LT 1045
i seems you already found the cause its a electrical problem look at all the wires you have a loose connection some ware the wires also like to break where they go into the clutch
Jun 28, 2012 | Cub Cadet Garden
Cub Cadet 2150 ignition problems. Need a wiring diagram to source problem.
don't have a diagram but i would check the safety switches jump them while looking for the bad one with a paper clip
Apr 11, 2012 | Cub Cadet Garden
Cub cadet LT-1042 blades spin when motor is turned on, pto lever does not turn on or off blades
sound like you have some wires shorted out follow the wires from the clutch back to the switch
Apr 08, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
I have a 2007 Cub Cadet Series 1000 Model LT1045 Does this model have a drive belt or is that belt just to run the fan on the tranismission.
hi there pauly46 here your model 2007 and before lt1045
take a look at this web site
http://www.partstree.com/parts/?lc=cub_cadet&mn=LT1045+Tractor+%282007+%26+before%29
this takes you stright to transmssion / belt drive system
http://www.partstree.com/parts/?lc=cub_cadet&mn=LT1045+Tractor+%282007+%26+before%29&dn=0125500003
this diagrams shows belts etc in the drive system , fan, trans etc
your answer is it does have a trans belt it is part number 954-0461
was pt number 754-0461
take a look at this site
cheers hope it helps
pauly 46
Diagram: LT1045+Tractor+%282007+%26+before%29 Drive System 1I136H & before CUB Cub Cadet 954-0461 (replaces 754-0461)
Apr 29, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Cub Cadet Op's Manual Model Lt1042 Lt1045 Lt1046 Lt1050 Logo
5,137 people viewed this question
Top Cub Cadet Garden Experts
dannydoesita
Marvin
Marvin
Dennis Key
Dennis Key
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
