How do you shorten the number of rings on a Samsung Gt-S5511T mobile phone
SOURCE: samsung mobile phone > GT-C3053 (GT-C3053) user
samsung GT-C3053 switch on and it shows greetiing msg again and again. it did not go next step
SOURCE: when dialing the mobile number
If it has diverted straight to the answerphone this means that either there are calls being blocked (check settings > phone settings > call barring (reject list etc.)) or that there is a problem with the network/sim card. Only your network will be able to tell you the exact issue but it also may be blacklisted if you have only just got it. Also bars on sim being used etc.
SOURCE: unlock code for a samsung gt-s3370b
hi you can use codes to unlock your mobile .you can get the codes from this site classicunlocking here they render the codes for all mobile models along with the instructions about how to use the codes in your mobile.
SOURCE: unlock code for samsung gt-e2120 mobile phone
Hey you can unlock your Samsung mobile using the codes. I found an unlocking service for your mobile from prounlocking.com .Once you get the code, you may follow the instructions at Mobileunlockguide.com .With the help of this you can unlock your mobile easily.
Testimonial: "very helpfull"
SOURCE: i have samsung galaxy 3,(GT-I5801)
Dear sir, Iam using samsung galaxy3 GT-I5801iam downlod fring when i connect fring then voice is mute so plese geave me a solution. Thankyou
