There is no sound for when phone rings,message alerts and alarm,but works fine when listening on call.I have set ring tone to loudest etc
SOURCE: Samsung Delve Increasing Ring
There is no way to change this setting. It is the way Samsung built the phone. A lot of newer phones are being made that way, including other brands. Don't ask me why, but I sell Alltel service and know for a fact it cannot be changed. At least they should give you a choice as to whether you want an ascending ringer or not. Hope this helps.
SOURCE: I cannot change the message
It took me many hours to work it out!
- Menu.
- Settings.
- Phone settings.
- Phone profiles.
- Select (highlight) the one you want &.
- Select OPTIONS with the left soft key.
- Click Edit (1).
- Use the directional key (right) to highlight the New Messages.
- Scroll down to Message Alert.
- Left soft key OPTIONS & select edit (as above).
- Then click the directional key until you hit either Downloaded Music or sounds (depending on where you stored your sound file).
- Select your file.
- Left soft key & select SAVE.
- Then that's it, done!
Please email me with if it works for u or not. [email protected]
SOURCE: on the samsung jet how do you change the message alert tone an
Hello Sir, For this you need to go to Profile menu. There on your preferred profile, go to the menu which personalizes the profile. There on Message sounds, you can change the volume, tone, vibration intensity ( if you use ). But you have to do it to all the other profiles which you want to personalize. Ex. If you want it on Normal and on Outdoor, you need to do the same task on both separately.
Thank you Sir, Have a nice day.
SOURCE: My Samsung Omnia Pro B7330
Solution is next, and i found it on xda-developers site, all thanks and credits to member xkaiser!!!!! Just go to this folder on your phone: my device/application data/Volatile and delete all 999 empty folders!!!! Dont worry about system, these folders are just temporary cache, it will not damage your system, but it will bring back your WMP and all ringtones!!! i tried and it work!!!!!! If you want to thank a man for resolving a problem, go here: http://forum.xda-developers.com/showthread.php?t=628968 He even made a cab file, after installing his file, just soft reset the phone and problem is solved!! Hope i helped
