Just a follow-up to thank everyone for th suggestions on fixing this problem.
I followed the instructions to remove front panel and cleaned out the small filter basket. There wasn't anything trapped in in, but it did have alot of soap scum that I cleaned out.
As I was replacing it, I noticed a small wire connection hanging down. I replaced this and my problem was solved. I don't think it was a clogged basket after all.
I can't figure out how to get the cover off the pump. I wanted to check the impeller and the pump itself, but was afraid to break the cover. Please help me to figure out how to open this black cover on the pump.
Thanks
• Verify Drain pump operation
• Pressure Switch Hose is in good condition and properly connected to Tub and
Pressure switch
•Verify there is not a siphon problem
•Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump,
Flow Meter, and Central Control Unit (CCU)
•Check all hoses for possible leaks
•Verify pressure switch operation
•Verify flow meter operation
•Verify CCU operation
