Daewoo FR-064R Refrigerator With Ice Box Logo
Posted on Mar 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Some times water flowing from bottom side of the fridge
My fridge daewoo fr-3501 is model,,,,,,,,some times water s coming from the bottom side of the fridge,,,,,,anybody knows about this,,,,,,give me solution...
Anonymous
Level 2:
  • Expert 400 Answers
  • Posted on Mar 13, 2009
Anonymous
Expert
Level 2:
Answers
400
Questions
0
Helped
225272
Points
937
There should be a drain pan directly below the icebox which needs to be emptied from time to time. Some units have a drainpipe connected at the back, if yours has one, it may have become blocked.
My daewoo fridge model FR-402KS is stop working because of high voltage of electric power, but when the door open the fridge lights is working.
If you have high voltage alarm, that will not stop light from coming on. Would make sure alarm is correct. First unplug fridge for 30 seconds then plug back in this should reset alarm If alarm stays off you should be OK if alarm comes back on have someone to check with voltmeter to make sure voltage is high. If not you probably need control board.
My Daewoo FR-291 fridge with freezer at topleaks 1/2 cup or so a day & onto floor sometimes. Hired one for $150 as told to turn ours off for 2 days. Leaked nxt day again. Thxs NZ
a thorough inspection of the tubes, filter, solenoid, ice maker and water dispenser should reveal the leaking component
also a thorough inspection of the defrost drain, drain tube, and dryer pan
3answers
My daewoo fridge freezer is leaking water from somewhere inside my fridga the model number is FR-4506S How can i fix this
Unless it has a water pipe plumbed into it then the water is melting ice or condensation, it's supposed to do this. You need to put a tray or some paper under it.
Whirlpool God 26cu ft French Door Refrigerator Model # GI6FDRXXY02 is leaking water on the kitchen floor. The water appears to be leaking in the front & water is leaking on both sides. Has anyone ha
There is usually a condensation pan at the bottom of a fridge. This can fill with water and over flow, causing what is happening. Also, the ice maker could be causing the problem because the water connections can leak at the back where they connect to the house water system.
DAEWOO FR-661NW GETS HOT
Just a thought i would check if there. Is it possible an ice build up around the fan could be stopping it from turning?
My Daewoo ERF 334M Fridge/Freezer has a little ice in the bottom of the freezer and is spilling water onto the floor - think it may be a blockage in the drainage pipe but do not know where this is located...
it go's down locate drain tube at bottom of freezer some time just defrosting manually will cure this drain gets small peace of food or tie from food freezes and blocks water from flowing warm water and a turkey baster works wounders
2answers
I lost manual book for my fridge,(daewoo) How can
Go to this site and after open the page, click on down "Download Page"
http://www.pdf-manual.com/user-guide-instruction-owner-manual-daewoo-fr-094r%28ss%29-23349.html
Hope, you got it.
Daewoo regrigerator - Multi flow -
Go here at the bottom you will find yhe manual you need the model # though.
http://www.e-daewoo.com/owners_manual.asp
Good Luck And Please Rate FixYa!
13helpful
4answers
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Water leaking underneath refrigerator/water freezing in bottom of freezer
I'm dealing with the same problem right now with the same refrigerator. The cold water tank (for the front dispenser) has a hole in it that leaks every time someone dispenses water from the front door. You will find the water tank behind the top slide-out drawer in the fridge. The leaked water flows down one of the water tubes through a hole in the bottom of the fridge and onto the floor. I'll bet you have the same problem. Good Luck.
Top Daewoo Refrigerators Experts
NOEL
NOEL
john h
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
