If there is no water on the floor, it would have to be that the water entering the washer is going through the drain tube because it is too low, or for some odd reason the drain pump could actually be running, pumping out the water as its entering the washer. If there is water on the floor, there could be a leak anywhere along the drain tubing, the drain pump itself, or even the drum/basket seal.
Was this helpful?
Yes
No
Popular Solutions for Frigidaire FGX831CS Top Load
Dryer making high pitch squeak, 3 years old. Model FGX831CS1 Frigidaire, Top Load Stacked Washer...
(More)
Dryer making high pitch squeak, 3 years old. Model FGX831CS1 Frigidaire, Top Load Stacked Washer /Dryer. Any ideas?
It's the older Frigidaire stacking top loader model with the wig-wag transmission and is belt-driven...
(More)
It's the older Frigidaire stacking top loader model with the wig-wag transmission and is belt-driven washer. I actually can't find the exact model number, so the one in the here in the post may not be correct. The only model number I can find is FLC271GW1. It makes a lout ticking noise during agitation and the motor seems overloaded when starting to spin. (I know this is the badly designed model where it spins and drains simultaneously) I have recently replaced the belt with the correct type. Any ideas?
my washer fills up but sometimes i have to keep the lid open until it finishes or it starts to...
(More)
my washer fills up but sometimes i have to keep the lid open until it finishes or it starts to agitate
I have a portable washer. The water tube that connects from the washer to the sink has a line shaped...
(More)
I have a portable washer. The water tube that connects from the washer to the sink has a line shaped hole in it. Is it possible to repair it myself, or do i need a new tube?
