I don't know how the rubber is supposed to lock into place...
It is the Rhode Gear Child Carrier
CoPilot Limo Bicycle Child Seat
The rubber piece is designed to lock the tung on the back of the seat to the rack. To get it in place you need to bend the tung down until you can insert the rubber piece over the tung and under the two fins so that when you release the tung the rubber is locked into place. You will likely need to bend the tung down quite a bit. The rubber piece has two circular ridges that should be between the two fins that it is pressed into. These ridges will prevent the rubber piece from sliding out.
So basically, bend the tung down and press the rubber piece into the slot that is created. It will start to become clear once you get this far. Just make sure those ridges on the rubber are on the inside of the fins.
