I have a 7ft carousel how do i get the replacement rubber pieces that they hang from i have the holders the rubber pieces that they hang from snapped in the high winds the other night .
I tool the plastic pieces apart to see how the rubber pieces was put togther. we had high winds and it snapped the rubber piece that they hang from its about 2 inches long of rubber . not sure where i can find a replacement .
Posted by Athena Spillman on
  • Susanewman
    Susanewman Nov 24, 2021
    [ JOIN US ] I get paid more than $60 to $70 per hour for working online. I heard about this job 3 months ago and after joining this I have earned easily $10k from this without having online working skills . Simply give it a shot on the accompanying site…
    Here is I started.……......>> http://Www.NETCASH1.Com
Fred
    Top Expert:
  • Washing Mach... Master
  • 35,504 Answers
I would use a bicycle inner tube to make new.
Posted on Nov 20, 2021
2answers
It-does-not-hold=the-wrap
Inspect that the rubber piece that holds the tube.Chance's are that it is worn and needs to be replaced. or it is missing.it wont hold the tube all the way if it is worn. A quick fix is to cut a piece of eraser of a pencil and glue it to the holder.
Rubber holder that goes over the ear has broken. Can it be replaced and how? Bluetooth still works find.
Hi cptpatterson,
  • If you have the rubber holder broken , then you can stick it carefully with superglue and it should work fine, but make sure that the glue does not go in the ear piece which can affect the ear piece and would not work properly.
  • There are spare rubber holders available at an authorized Nokia Shop from where you can get it , but I would suggest if you want to save money you can just use super glue in small quantity and use it at the broken surface and it will work find for you as this device does not need a huge amount of strength that it has to bear.
Hope that helps..:) Let me know in case you have any queries, your feedback would be appreciated.
8helpful
Dyson dc11 replacing motor
DYSON DC-11 MOTOR REPLACEMENT
1. Remove dirt cylinders as normal
2. Using large flat screwdriver, remove airway splitter and hose
3. Undo 6 Torx screws from top and one at the back under tool holder
(Note that 2 front screws are shorter)
4. Make sure the screws are completely withdrawn
5. From the back, withdraw tool holder section
6. Unhook and withdraw hose holder section
7. Place large flat screwdriver behind the wheels and forcefully snap them off
8. Remove 2 more screws under each wheel
9. Cover now lifts off
10. Motor pod is now visible. Remove its 4 screws and lift its lid
11. Motor can now be lifted out. Disconnect its 2 wires
12. Remove the rubber base and transfer to the new motor
13. Connect wires, Red to Brown (Live) and Black to Blue (Neutral)
14. Make sure motor is correctly fits on its alignment studs in the pod and replace its cover and 4 screws
15. Replace top cover of machine, and the 4 screws under the wheels, but no other screws yet
16. Turn machine on its side and hammer each wheel back on - take care that no fingers are under wheels while doing this
17. Stretch and snap hose holder back into position
18. Slide tool holder forward into position
19. Replace the 6 screws into top section, and one into tool holder section
20. Replace filters, airway splitter and dirt cylinders, and the job is complete :D
How can I replace broken mirror glass volvo S40 2002?
You can replace it a couple of ways, my wife broke my side mirror with a paint ball gun, so I just cut a piece of mirror and glued it in the holder. Worked great for years, Till I found a new mirror, and took the real glass out and snapped it in the holder. But you can remove the holder by taking off the plastic cover inside the car behind the mirror, unbolt the holder and hang on to it, it is heavy. You might have to pull the door panel to get the wire disconnected. Then you can either replace it or work on it easily. Hope this helps.
2answers
Mine is model RF266ABRS, but both a white rubber piece (is this the waxy part??),and a semi-opaque plastic bracket became dislodged. The result is the same as others describe, the unit makes ice but in...
You can purchase this part as a replacement for your ice maker. it is a simple float switch that turns off the water when the tray is full.
If it is broken, the tray will either overfill or not fill enough.
There are many online spares shops, so find the assembly you require.
You can replace it as a DIY fix observing standard safety procedures.
Earpiece holder around ear seperated - soft rubber from plastic.
If you go to your cellular providers retail location, they have a customer service desk for repairs, etc. they will have parts. Hope this helps
KEY THAT POPPED OFF
Make sure you have all the pieces of your key, including the small rubber piece that is usually on the keyboard, a small plastic piece and the key. Just make sure the piece is on, or just rest it on there after the next step.
Replace the plastic piece next. There is generally a small notch hanging out of the keyboard, place the corresponding hole in the piece underneath, then put it so that it covers the spot, the apply pressure and secure the remaining points.
After this, generally it is just a matter of snapping on the key, try to use a back to front motion when doing this to ensure it is secure. And, That should be it
If your key and the plastic piece are still together, essentially just use the third step, taking care to make sure it catches the notch.
5helpful
2answers
A part fell out of the ice maker - makes 'soft' ice???
It goes on the bottom of the ice tray and snaps in that is the sencor that tells when the ice is frozen
33helpful
6answers
How do I change brake light bulb on 2005 Nissan Altima
The first objective is to figure out which bulb you need. I had to replace the bulb for the largest light which was a Sylvania 3157. The next objective is to remove the dang plastic carpet holder/net clip. Recognize that it is a two part piece. Use a flathead screwdriver for leverage. Pry the cap off by levering the screwdriver in the slot on the holder. Then go behind the carpet and pinch the plastic pin still holding the holder in place. Next,pry off the while plastic pieces from the two bolt/nuts you'll need to remove (see manual). Remove the nuts and give the two screws a push from the inside so you can see how the whole light casing comes off. Pry it off from the outside. On the backside of the bulb holder, turn bulb base counterclockwise and gently remove. Pull bulb upward and replace. Do not touch glass on new bulb with your fingers (wear non-powdered rubber gloves). Make sure the bulb snaps in place. Follow these instructions in reverse. Smile, you just learned something new and saved yourself some easy money.
Washing Machines Logo
Top Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
