-You mean the opening in width is too wide then
it suppose to and the rack keep falling down?
-If so then look for other rack instead its brand and must be
fit in the groove good. Or ask some one do wielding to wield another 3/16" diameter metal next to the 1 side of the rack, (Add on to make wider) so it can stay in the groove.
There is a star wheel on the back side of the unit this wheel raises and lowers deck to make level. There is a lock bolt that keeps it in place, they often loosen and the deck falls. Loosen lock bolt adjust deck to same height on both sides.
This is common, I usually fold some paper, and jam it in at each end, not a pretty repair but effective. That or in worse circumstances a wee drop of Hot Glue, is a great fix, it can be simply picked off if ever you need to do anything with the battery.
Thanks for that. I will see if it will stay put.
M
there are small lock mechanism there with a lock sign just out the batt and lock it otherwise see if the latch is broken that holds the batt
