20 Most Recent MSI Wind U100-030US Laptop Questions & Answers
just insert the cd and boot the computer from it and then choose fix problems
MSI Wind... | Answered on Mar 10, 2019
Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in the safe mode then Scan your computer for viruses. Some viruses can cause a black Screen , especially ones that infect the master boot record (MBR) or boot sector.
Update drivers for your hardware. black Screens are hardware or driver related so updated drivers could fix the cause of the STOP error.
Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including black screen.
If it didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of black screen screen
MSI Wind... | Answered on Feb 18, 2019
Turn the laptop upside down and remove the plates one by one. Wherever you see a button cell, remove it for a minute or so and then reinsert it and put back all the covers. Power on and boot up the laptop. And remember not to use the password again. And if you have to then use such that you can not forget ever.
MSI Wind... | Answered on May 05, 2018
Yes the AC Cord does go bad , you can also look at the power jack at the back of the Laptop to see if it is loose when you plug it in. I always start with the plug they are usually cheaper than a battery.
MSI Wind... | Answered on Nov 02, 2017
Try a few charge/discharge recharge cycles to see if you get an improvement. If negative, then replace since it is bogus.
MSI Wind... | Answered on Aug 25, 2017
thats a lil odd seems as if the motherboard is trying to determine what speed of ram you have but after about five mins or more if it doesnt do anything try reseating the ram cards if after five mins again try using just one ram card in one slot if it turns on fully turn it off and move the same working ram card to the next slot if any slot fails then that ram slot is dead if you have more then one ram card test it using the same method if the ram card does not work then that ram card is bad
MSI Wind... | Answered on Apr 22, 2017
keypad may need to be taken off and cleand.
MSI Wind... | Answered on Mar 30, 2015
Missing NTLDR fix
Windows xp pro.
Windows will not boot and you get a disk read error
NTLDR is missing
To repair this you will need your windows installation cd.
Step 1. insert windows installation cd and restart the computer.
Step 2. press any key to boot from cd.
Step 3. after the files load press r to repair windows. This will open the recovery console.
Step 4. You will see the Windows file... 1: C:\Windows -- Press 1 and enter
Step 5. Type administrator password if you use one and press enter.
Step 6. go to the directory that your installation cd is in... mine is D so type D; and hit enter
Step 7. type cd i386
Step 8. copy ntldr c:\
Step 9. Your done. Now type exit , remove the installation cd, and restart your computer
MSI Wind... | Answered on Mar 12, 2015
If your Laptop has no warranty than you open your laptop back-cover,open your laptop bios battery,turn it on & turn off it again.connect your bios battery again, turn it on and see your bios password has been deleted.
MSI Wind... | Answered on Feb 25, 2015
Those are not easy to get to but u will need to dislog the bios battery and re-insert it to remove the password lock.
hi
check for the necessary ip addressing formats as well as if any DNS server addresses are required to connect to the network
if all is fine then try
right click on the network icon click on repair
try surfing if still not able to surf try the steps a couple of times
cheers
MSI Wind... | Answered on Aug 13, 2014
That is quite common and can be windows updates or spurious downloads that corrupt the system files. Restoring the complete system will bring it back but it may be something to do with either the system drivers or keyboard driver. Try downloading fresh drivers from msi.
MSI Wind... | Answered on Jan 31, 2014
The BIOs Cracker, a free or paid program can be found on line. That will allow changes to be made, however, any interruption can render the Bios useless and you may not access the Boot instruction set henceforth.
MSI Wind... | Answered on Jan 09, 2014
It sounds like you have a faulty screen, if under warranty contact support for warranty, otherwise take to a local tech to see if the problem can be rectified.
MSI Wind... | Answered on Dec 20, 2013
Press and hold the Fn button, and then press the F11 button repeatedly to enable or disable the 3G/ Wireless LAN/ Bluetooth/WiMax function recurrently.
MSI Wind... | Answered on Oct 31, 2013
Please check keyboard settings under Control Panel.
MSI Wind... | Answered on Apr 01, 2013
MSI Wind U100-030US Laptop Logo
189 questions posted
Top MSI Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Wind MSI
  • Wind MSI
Most Popular Question
msi u100 function key commands not
  • Computers & Internet
