Motorola Mobility Motorla MOTXT912 DROID RAZR Verizon 4G Smartphone Logo
Need guide either Manuel or online for Droid razr motxt912
Tracfone customer service
Contact Tracfone support for assistance.
Mark
Motorola Support
2helpful
2answers
Make widgets bigger
There may be 3rd party apps that enable this.
Mark
Motorola Support
Why does my smartphone say I typed in wrong password. I did not try to log in there
if you lost your password then u must reset it. and it will cause All Data Lost.
Will not turn on
make sure you have a stable internet connection, reboot the device and try again
I charged my droid razr maxx to 100% then battery keeps dying within 15 minutes pls help
Hello My Dear Friend:"::
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Washed my phone
take it all apart and let air dry completely then put back together.
Droid razr will not turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
1helpful
2answers
I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
