Which product key are you referring to? Is it the Windows Operating System product key? If that's what you are talking about then I suggest that you contact microsoft customer service.
Hi Amanda Gonzales - If you would like to recover just the number for your product Key, it is usually located in the Registry of your computer. Product Key Finder is a free app that you can download and then look up the number. Then, copy down somewhere safe to have if you need to reinstall your copy of Windows. *This app will ask to install other programs, so be sure to just install the one you need. Hop this helps.
different laptops have different product key even if they're from the same model range. if you haven't formatted the drive, you can use a "product key backup" software provided that you can still log into windows to backup your activation info beforehand and restore this info after you finish with the formatting. otherwise, you will have to forward this issue to Microsoft. ABR Activation Backup and Restore directedge us
i can give you patch instead of product key, it is very difficult to find the product key of your OPS.
you can leave a comment so i can give you the patch for your windows vista premium.
Solution one: Turn the All-in-One off and on again
Follow these steps to turn the product on, and then off again, to reset the print mechanism.
Press the Power button (
) to turn off the product.
Wait 15 seconds.
) to turn the product on again.
NOTE:
The product might go
through a warm-up period of up to two minutes. The product lights might
flash and the carriage might move. Wait until the warm-up period is
complete before proceeding.
Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
If these steps resolved the issue
, and the self-test report prints
, there is no need to continue troubleshooting. Reconnect the USB cable, and then try to print again.
If the issue persists
, continue with the next solution.
If the self-test report does not print
Solution two: Clear any paper jam
Jammed paper can cause the carriage to stall. Follow these steps to clear any jammed paper.
Step one: Remove any loose paper
Remove any loose paper from the input tray and output tray.
CAUTION:
Do not remove jammed paper at this stage. Trying to
clear a paper jam from the front of the product can damage the print
mechanism.
Step two: Clear the paper jam from the back of the All-in-One
Use the following steps to check for and remove jammed paper from the back of the product.
Disconnect the USB or Ethernet cable from the back of the product.
Disconnect the power cord from the back of the product.
Remove the rear door. Push the door latches toward each other, and then pull the door away from the product.
Figure 1: Remove the rear door
Illustration of removing the rear door
Gently pull the paper out of the rollers.
CAUTION:
If the paper tears when removing it from the rollers,
check the rollers for torn pieces of paper that might remain inside the
product. If any torn pieces of paper remain inside the product, more
paper jams are likely to occur.
If you are printing labels, see if any
are missing from the label sheet. If any labels are missing, find them
inside the product, and then remove them carefully.
Reattach the rear door. Gently push the door forward until it snaps into place.
Step three: Clear the paper jam from the front of the product
Follow these steps to remove the paper jam from the front of the product.
Open the cartridge access door.
Figure 2: Open the cartridge access door
Illustration of opening the cartridge access door
If you find paper jammed in the
product that cannot be removed through the rear door, gently remove the
paper through the front of the product.
NOTE:
Remove paper from the
front of the product as carefully as possible. If any torn pieces of
paper remain inside the product, more paper jams are likely to occur,
and this could damage the print mechanism.
Close the cartridge access door.
Figure 3: Close the cartridge access door
Illustration of closing the cartridge access door
Reconnect the power cord to the back of the product.
) to turn on the product.
This article describes how to find the product key if you cannot locate it, or how to obtain a new product key if the product key label is damaged or is missing. If the product key label is damaged or missing and you have to replace the product key, go to the "How to replace a damaged or lost product key for a full version" section. If you have your product key and it is not working, contact Support at the following Microsoft Web site:
http://support.microsoft.com/contactus/?ws=support
The key usually is on a sticker/label on the PC itself. Otherwise if you lost it, I'm afraid there's nothing much we can do since we cannot prove to Microsoft that there really is a missing key, since there are plenty of people who will claim they lost there key in order to obtain one, even when they never owned one. You see what I'm saying here?
There's an option though. When Windows is installed it mostly has an option to register it a Microsoft. If you did you can call 'em and tell them to look op your registration. That'll prove you have legitimate copy of Windows.
You can contact them by clicking the Contact us link at the bottom of the Microsoft site's main page. [Contact Microsoft]
Let me know if this helped solving your problem, please rate.
