SOURCE: Sylvania DVR90VE DVD Recorder / VCR - formatting DVD-RW
This unit only supports 2X -RW discs or 4X -R discs.
SOURCE: sylvania dvr90vf dvd recorder
Error message when tying to setup to record..
Disc DVD-RW 4x. 4.7gb 120 min.
Recording Error
Can not record on this disc.
E4 54037380
add
SOURCE: unable to "dub" my 8mm tapes onto DVD-R using my Sylvania DV90VE
From comments posted on the Internet by other Sylvania users with a similar problem, I learned that I had to use a 4X DVD-R (the ones I had been trying to record on were 16X). And I found that Office Depot sells the sometimes hard-to-find 4X format, so that's where I'm headed right after lunch. Thanks.
SOURCE: Cannot read DVD+R discs generated with Nero 8.0
The DVD-R format was developed by Pioneer in 1997[1]. It is supported by most DVD players, and is approved by the DVD Forum. DVD+R is a later version and not supported by a lot of machines. Swith to -R, should work, I use Nero 9 upgraded from * and have absolutely no problem as long as I use DVD-R discs, lots of problems with DVD+R though. Good Luck!
SOURCE: How can I get a Region 4 dvd to play on my blu-ray player?
After getting clarification from Fixya I can pass the links below to you to check yourself
Some players are harder than others to do this but you may want to try here or here
Comments:
Toshiba's and JVC's are the harder ones to do
I use a Phillips myself as it is not only cheaper but has much more going for it than many of the higher end units. i throw anything at it and it just plays
The older the unit that harder it is to do the region free thing with.
I let my EX have the panasonic (big grin)
If you cant find a fix then look at the codes available for cheaper brands and how easy it is to do it before you purchase one.
Just a thought.
