Just set up email account. worked first time for me.
from menu: <messages><3 email
inbox><ok><options><email
accounts><ok><ok> on first account (Account 1)
fill in email account details:
Account Name: enter a arbitrary name that is relevant to you.
SMTP server: enter smtp address of your email provider
e.g. mail.isp.com.au
SMTP port: leave default of 25, unless advised otherwise by your provider
Email retrieval server type: pop or IMAP4 generally pop will work but use config as provided by isp
pop3 server: typically same as SMTP server, unless otherwise specified
POP3 port: 110 is default
use ssl checkbox. I left unchecked, this would provide a higher level of transfer security but makes config more complicated
Keep on server checkbox, I checked this as my mail emailis my laptop,
so I don't wantthis to take all the messages, this way both devices can
get messages, assuming leave on server is enabled on other email client
on Laptop/PC but set to delete after 7 days.
My address: enter email address in the form: [email protected]
user name: enter the configured email account user name. usually the name before the "@" in your email address
Password: enter password of the email account to allow access, note case senSaTive
Use SMTP authentication checkbox. i left this blank as this is not required by my isp, although some do require this.
Same as POP3/IMAP4 checkbox. only needed if SMTP authentication
checkbox is set. if SMTP authentication is set then a name and password
is required, generally the same as POP3 name/password entered earlier
so just select - same, otherwise if isp setup requires differnt use
fill the username / password fields.
<Save>
ensure newly created account has tick in the box next to it to enable it.
should work.
To send:
to test create an email message and send. may need to add email address to a contact first.
To receive emails:
<messages><email inbox><options><download> this will download any emails on your mail server
all worked well for me
best of luck
