I have problem with volvo s40 sport 2003 radio shows OFF
SOURCE: where is the fuse for the radio , stereo for volvo s40 xs
Passenger compartment fuses are all behind the drivers side (left) kick panel. You should only need a #2 philips head screw driver to remove 4 or 5 screws. After you remove the screws gently pull out on the lower right corner to disengage a plastic tab. The panel then should now come out disengaging metal tabs on the upper to corners. Fuses are on the left.
SOURCE: volvo s40, loosing power
if you have over 125k miles on it chances are your about time for a new catalytic convertor... can cause a rotten burnt smell... lack of power.. and even a stall... or no start
SOURCE: Radio code for volvo s40
If the display says "Off" the radio is locked from incorrect code input.
You need to leave the key in the accessory position with the radio on (display reads 'Off') for about two hours.
After that it should ask for he code again. You have three tries before it locks again.
Some radios are different, but typically you use the knob to adjust the numbers, push the knob in to move to the next number
