Polaris 2004 Scrambler 500 Logo
scott deters Posted on Apr 06, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why doesn't my 4 wheel drive work
When I switch from 2 wheel drive to 4 wheel drive, it doesn't engage what could be the problem ? might it be as simple as a bad fuse ?
Scott Tx
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Polaris Expert 604 Answers
  • Posted on Mar 29, 2014
 Scott Tx
Polaris Expert
Level 2:
Prodigy:
Answers
604
Questions
0
Helped
276495
Points
841
It could be, polaris uses an electronically controlled lock in hub. broken wires or bad switch also.
Charles Edwards
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Feb 22, 2015
Charles Edwards
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
4589
Points
11
Could just be burnt out they work like a magnet and if not kept clean they will look on and stay on or not lock at all. The main thing is to keep oil in the front hubs
I purchased a used 2005 ATV Arctic Cat 400. It has a switch to engage the 4 wheel drive but it does not work. What might be the problem? Thanks
Try bypassing the switch.. if that works,, its the switch..
..just an old method...
If the switch has two wires, disconnect the switch and see if it will go into 4WD.. if nothing happened.. then jump the two wires and see if it goes into 4WD...
If not..repost with more details about the switch.
Dec 16, 2016 • ATVs
2002 Polaris Sportsman 700 vtwin. Why doesn't 4x4 work?
not sure about that model but other polari I've worked on use electronic hubs to engage the four wheel drive. check the wiring to the hubs or possibly a bad switch.
Mar 23, 2016 • ATVs
1helpful
Wont go in 2 wheel drive but switch works light come on dash ?
2004 Sportsman 700 AWD not working..... - Polaris ATV Forum
www.polarisatvforums.com > ... > ATV Repair and Maintenance
Feb 18, 2013 - Go Back · Polaris ATV Forum > Polaris ATV Technical Discussions > ATV ... AWD wont engage. 2. The instrument / speedo works. 3. The AWD switch is ...Polaris ATV Junkie! .... four wheel drive not working polaris sportsman. Won't go into 4 wheel drive
Feb 1, 2013
4 wheel drive not working
Nov 13, 2011
2004 700, 4WD engages by itself
Oct 28, 2011
4wd is stuck on
Dec 3, 2009
More results from www.polarisatvforums.c
How to test my 4 wheel drive electricals
On my 4 wheeler if I raise the front wheels off the ground and with the 4 wheel drive engaged you should not be able to turn the front tires two revolutions. You need to be more specific as to what you are trying to do because there are other electrical things that can be checked. Like if the 4 wheel drive will not engage. Previous test is only to see if the front end is engaged in 4 wheel drive.
No 4 wheel drive/where to start looking for problem
Sounds like the switch or a relay since the front is not engaging.
Feb 15, 2014 • ATVs
4 wheel drive locks in one side one side will not some times makes a sound to if 2 sides are in
Model? If you put it in regular 4WD it will usually only spin one tire. If you have diff lock and use it, it locks both front wheels but can be hard on front end parts. The front end will do some clanking and popping because it doesn\'t really like diff lock.
Aug 25, 2013 • ATVs
All wheel drive doesn't work
Take a test light go to front actuator and see if power there when you puss the switch check fuses
Jun 20, 2013 • ATVs
Top Polaris ATVs Experts
john h
Sean Wright
Sean Wright
ZJ Limited
ZJ Limited
Are you a Polaris ATV Expert? Answer questions, earn points and help others
