I tried to fax a document to my friend with hp1040 fax machine. The process is ok until DOCUMENT READY appears.I don't know how to send it. I am anxious to know. Thank you!
Dial the phone number and then press start.
Hi, thanks for using FixYa,
1- Place the document to be sent in the document feeder (up to 10 pages).
2- Dial the number of the destination fax and press START/ENTER. Then it will dial the number and if the destination fax gives the reception tone, your document will be sent.
Good Luck!!!
When you put the document in. You then select Scan and type in the phone number and then you should press Ok or Start and it should fax the document. Easy as that.
Benjamin
There should be a send button you push after you dial the number..it should say start on it and it will do the rest.the button to send should say start on it.
In the settings option first apply fax mode then you will on screen get the instruction to insert the fax number of the party anfd it will ask to send.
thats it.
When you see document ready message, press Send button.
Hello kchen2atlant,
1. Load your document face down
2. Enter your friend's fax number
3. Press Start/Enter
You can find an on line manual to your machine at
http://h10025.www1.hp.com/ewfrf/wc/useCategory?lc=en&dlc=en&cc=us&lang=en&product=425911
If you found this info to be helpful, please rate this solution.
Thank you.
BelgianAlien
I did it just as your instruction.when DOCUMENT READY appears. What I am supposed to do for sending it? Thank you!
MY hp1040 fax machine doesn't have "SEND' button
