If i load up the cold dryer with clothes and turn it on, it works fine. Once the drying cycle is over and i take out the clothes, if I have another load to dry immediately after, when I push the start button, the drum does not turn and i can hear a low humming noise. If I let the dryer cool down, then push the start button, it works fine again. This just started a few days ago. I have had the dryer for 7 years with no issues. Any ideas?
SOURCE: The Drum on my LG DLE2512W Dryer will not turn
no problem with motor or control board. fault is with the motor capacitor only. this is often attached to the motor or near it. the value of the capacitor will be printed on it (usually about 8uf) and you should be able to source from an electrical spares shop
SOURCE: LG DLE2532W Electric Dryer doesn't allow adjustment of drying options
it may be possible the contol is bad can you change the settings at all
SOURCE: LG DLE0332W Electric Dryer- The
Had the same problem, dryer got hot but didn't stay hot. sounds like you have a bad sensor and it sounds like it's out of warranty.
SOURCE: LG Gas dryer doesn't dry clothes in one cycle
Have you checked your outside vent while it was running to see if the dryer was venting 100%. If your clothes are hot and humid I would say clean your vent pipe has a blockage and needs to be cleaned out. Also as far as the burning smell you could take the front off (unplug first) the dryer of by removing 4 screws one above and one below the latch and two at the bottom and there are two clips one at the top left and right push in with a puddy knife and lift the top up a couple inches and lift the front up off the bottom holders. Then you will have access to vacuuming the lint that is floating around the burner.
SOURCE: items in dryer are not quite dry, cool down cycle
check and make sure it has a clear clean vent.no kinks in vent hose.if yours vents thru roof then you may want a chimney sweep to come and sweep your vent out.if it goes thru a wall check and make sure know blockage.
My dryer is doing the same thing (Whirlpool WED5840SW0). Did you ever get yours fixed?
