Windows XP, Windows 2000, Windows Me, Windows 98, Windows 95, Windows NT 4.0, Windows NT 3.51, Windows NT 3.50 epson10701.exe - 5.6MB - posted on 05/02/03
This self-extracting file contains the Epson LX-300+ Printer Driver for Windows 95, 98, Me, 2000, NT 3.50, NT 3.51 and NT 4.0 (Printer Driver v2.0E, Core Driver Disk v2.0).
Normally installing the os on a different mechine, and then putting into another pc dosent work.
If the hardrive is the oringinal drive, which came with the system, and you want to install xp on, you will have to use a dos disk with fdisk on it, delete all partitions on the drive and create a new partition, then start loading windows, it will give you the option to format the drive for nt(ntfs) file system and setup windows.
If you do that and it still gives you protecting files error, you will have to take the side panel of the computer tower, unplug from the mains and take the cmos battery out for about 30 secs, put the battery back in, plug in the mains and reboot the computer, start loading windows again Hope this helps and post back if you need further assistance.
Just putthe cd windows xp to the rom drive and re-install the windows, be sure that your priority boot will be the cd rom then continue the installation and the system will repair your program.
Go into the Control Panel and check out this category:
Power Options - See if your computer is set to shut down or enter standby mode at a specified interval. If you do not want it to, change the setting to an acceptable one. You will have options for time until the monitor turns off, the hard drive turns off, the system stands by and the system hibernates.
Boot the computer using the XP CD. You may need to change
the boot order in the system BIOS so the CD boots before the hard drive.
Check your system documentation for steps to access the
BIOS and change the boot order.
When you see the "Welcome To Setup" screen,
you will see the options below
This portion of the
Setup program prepares Microsoft
Windows XP to run on your computer:
To setup Windows XP now, press ENTER.
To repair a Windows XP installation using Recovery Console, press R.
To quit Setup without installing Windows XP, press F3.
Press Enter
to start the Windows Setup.
To Repair Install, press ENTER
To Repair Install, press ENTER \r\n'); FP_changeProp(/*id*/'layer1',0,'style.borderStyle','double','style.borderWidth','3px','style.padding','5px','style.backgroundColor','#F9F4D5','style.backgroundImage','url(\'edgbkgnd4.gif\')'); FP_changeProp(/*id*/'layer1',0,'style.visibility','visible')" onclick="FP_changeProp(/*id*/'layer1',0,'style.visibility','hidden')" width="15" border="0" height="21" />
do not choose "To
repair a Windows XP installation using the Recovery Console, pressR", (you
Do Not want to load Recovery Console).
I repeat,
do not choose "To
R".
Accept the License Agreement and Windows will search for existing
Windows installations.
Select the XP installation you want to repair from the list and press R
to start the repair. If Repair is not one
of the options, END setup. After the reboot read
Setup will copy the necessary files to the hard drive and
reboot. Do not press any key to boot from CD when the message
appears. Setup will continue as if it were doing a clean install,
but your applications and settings will remain intact.take care god bless
Driver for : OS: Windows XP,Windows NT SP3,Windows NT SP1,Windows 3.11,Windows 2000 SP3,Windows 2000 SP4,Windows 95,Windows NT SP2,Windows ME,DOS,Windows 98 SE,Windows NT,Windows 98,Windows 2000 SP1
windows nt is a operating system some software works only with windows 98or only with windows 2000or only with windows xp/nt windows nt is the same as xp i think the software ym makeover magic works windows nt platform you should have the operating system in which the ym makeover magic works to know which operating syatem works just see some readme files in setup files folders of the ym make over magic there will be file stating readme in that they will give operating system comapatiblity windows 98/2000/server 2003/xp/media center /vista they will specify like this see the compatiblity and then install the operating systm and then install the software
