I have water coming out when machine fills from door and draw at front. The seal on the door is fine, and I have cleaned out the filter at back, which was dirty, but still leaks?? Any one got any suggestions??
Had the same problem. I unplugged the machine from the mains. pulled it out from the unit and removed the lid. checked the black rubber hose which leads from the drawer to the drum. it was full of water. i carefully squeezed the pipe and tried to clean it out with warm water to see if it was clogged. still leaking. i then Removed the green paddle on the inside and turned the drum to line up with the black rubber hose that leads from the drawer. I very carefully used a wire coat hanger to put through the gap in the drum left by the paddle. Moved left and right, oh look.... A sock! I manipulated it out of the gap, checked the hose. Water had gone. Put everything back together. No leak. All done in under an hour :-)
Is the pipe were the water gose in clear it is leakiing by the door cus the water flows down the machine and own from the door hope this helps.
hi if you are saying machines fills and before it actually starts its wash cycle ? the water is leaking from door and the drawer on the top front of machine ? it sounds very much like the machine water level is over filling ? there is a devise on the inner r/hand side of machine located on side panel it is circular and has an elec connection and a small hose either rubber or plastic attached to it ? this devise regulates w/level by water pressure in tube which act on a diagphram in the unit and trips out the water flow from feed pipes via solenoid/s for hot/cold supply may i suggest ou unplug machine and water pipes if need be ? then remove the top screws from rear panel (these also holt the top panel) then tilt+nd pull back top pane clear from front and lift off panel look inside machine for devise mentioned above now possibilities?? either small hose is kinked ? or blocked somewhere ? this will not allow water to actuate devise ? or you may have faulty connections or devise it self may be rusted inside? if you have/know somebody who has a volt meter they can check both elec feed to devise and whether it is shutting off at correct w/level thus shutting off water supply solenoid/s water level should only fill to approx 1/2 level in drum max visible thro door glass ? either way if you check as above it should reveal the fault and you can diy saving $$$s on repair hope this helps look 4ward to any update you may post on progress good luck and best wishes
