If the problem is consistent, FIRST check to make your machine is level. Also try cleaning the machine out with no clothes in it using white vinegar on a hot wash. If you're having a problem with high speed spin with NO load in it, it could be shaft/bearing related which would probably be too expensive to fix. Otherwise you could simply just be adding loads incorrectly or overloading it.
the fluff filter just needs hand tightening up a bit more to stop the leak. if not there could be a bit of fluff trapped between the seals. Remove it again and have another look. Make sure also you don't cross thread the fluff flter which makes it feel like it is screwed in properly when it isn't
hi there ....the wiring schemematics can be obtained from meile with no problem .....if you can tell me what area in uk youn reside i can advise you where to obtain your diagrams
no lights on the board
