The power button stay's orange. Will not start and at no time will the power light change from orange to green. If one were to guess it acts if the power supply isn't working.
SOURCE: Flashing Green Light next to voltage switch
For problem #1 there is a MBR (Master Boot Record) problem, meaning that Windows is unable to find Windows. This can either be a software problem or a hard disk failure. If you have your Windows XP disc boot up with it in your cd drive and when it starts press 'R' for repair as this wil repair system files and you will not lose any settings or doc's. When you are running go to your hard disk drive manufacturer and run a diagnosis and repair if neccassary. Problem #2 should sort itself out if left unplugged from the mains supply and the power supply unit for 15 mins or so. If not there is a power supply that needs replacing.
SOURCE: Gateway 700XL, yellow light only when power is pushed on.
You are on the right track. First, swap out the power supply. That normally is the issue. If that's not the issue, verify that the power switch indeed is working. You can do that by determining which color wires are for the power switch, then hold a multimeter set to resistance on the ends of those two wires. When the button is pressed, it should go to zero. If not, then the switch is fautly. That is an unlikely scenario, however. If the new power supply fails to work and the switch is okay then the problem is the motherboard.
Thanks and please take a moment to rate as fixya.
SOURCE: Fan is running, power button with blue light is off, cpu won't boot up
Your cpu might have died. As the computer is starting tap F8 and choose last known good configuration to see if you can get it started.
This is typical of a failed power supply. Look on the back of the power supply, there may be a red switch for input voltage. Unplug the power cord, flip that switch a few times and then plug the cable in and try again. If nothing changes, see if there's a small black button on the back of the power supply. If there is, unplug the power cable and press the button and hold it for 10-15 seconds. If an LED flashes or turns on, then plug the cable back in and try again. If this all fails, replace the power supply.
SOURCE: The computer will not start up. But when we plug
yes this is power supply problem, the SMPS (Switch Mode Power Supply unit) inside your computer has gone bad. it has to be replaced to make your computer run, thank you,, plz rate me,,,
