I can hear the projector turn on when I flip the switch on and the power display light becomes orange. When I press the power button on top, the power light stays orange and the status light becomes green. The lamp light stays off though (no red, no orange, no green). At this point the fans haven't turned on and the lamp isn't on. Then the status light just goes off as well and the power light stay on standby... Any ideas?
SOURCE: i have a nec vt560
The projector is in standby mode, which is a good sign.
When you press the ON button for "at least 2 seconds or more", what happens.
Do any lights come on at all?
SOURCE: LAMP not switching on NEC HT410
I had the exact same problem and solved it. After calling NEC tech and getting no help, my son and I decided to:
And it worked. Here's what we did.
Works fine now! Dont know if it was technical solution but solved it for us! Good Luck!
SOURCE: Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
SOURCE: will turn on but the
The steady orange light indicates that there is an error on the lamp of your projector. This is also the reason why it won't turn on.
• Ensure that the lamp cover is installed correctly.
• Check to see if the projector has overheated or the lamp usage exceeds 1100 hours (2100 hours in
Eco 2 mode and 1600 hours in Eco 1 mode). If there is insufficient ventilation around the projector or
if the room where you're presenting is particularly warm, move the projector to a cooler location.
The problem has to do with the lamp so have it checked.
Good luck.
