Oven door will not lock
SOURCE: Admiral electric range with self cleaning oven
There is an automatic lock feature on this unit that after 1 hour will unlock itself.
hope that helps!
SOURCE: Manual lever to lock self clean oven wil not lock
After sliding latch to its locking position did you press the self clean button on the control panel?
SOURCE: After cleaning my GE XL-44 self cleaning oven, the
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Assuming the door is still locked after cooling, then either the door switch is bad or the wiring from the control panel to the door switch has a problem. First disconnect the power from the oven. Then check the wiring and connectors (from the control to the switch and back). If those are fine, you need to replace the door switch. After replacing the switch or fixing any bad wiring/connections, reconnect the oven to power. Press and hold any key on the panel for at least one minute to clear the error. You should see F2 on the LCD panel. Press Cancel to clear the error then check to see if any new error (or the old one) message occurs. (Usually a new error message will come up within a minute.)
Which model Whirlpool oven do you have? If you add a comment with the model number, I may be able to provide a parts list and diagram of the unit.
I hope this helps.
