Can't reset trip meter because reset button is broken, can I buy these button. They seem easy to install.
SOURCE: Trip meter reset in Ford Focus Zetec 2003
You have a blown fuse in the interior fuse block I can't remember the number. Use a test light to check them
SOURCE: 1999 vw passat 2.8 v6 speedo not working. trip
most of the older cars have a cable driven speedo but newer cars are elecitronic it could be the little motor behined the gages or the wiring going down to the tranny check the cheepest first
SOURCE: reset button on instrument panel
You have three options here.... None of which you will like. Option A: remove the dash and the instrument panel and attempt to replace the entire unit yourself. ( PAIN IN THE **** ).
Option B: Pay service shop to do aformentioned repair ( labor + Part = most likely going to cost a minimum of 200 dollars ranging all the way to 400).
Option C: Live without it. Your going to come off some money with this one. Getting an odometer system replaced can be very very expensive. If your system is Digital you might actually save some money as far as labor is concerned.
Testimonial: "thanks for the good advise, i'll live without it!"
SOURCE: how to reset trip meter
The two buttons that control the trip options are on the dash adjacent to the hazard warning button. Press the TRIP button untill it shows a small A or B in the top left (say average mpg) then press the upper part of the toggle switch marked RESET/CLEAR and hold it for about four seconds, this will display A or " B resetting" depending on which trip you are currently in, then everything on that trip is reset to zero (mileage/mpg/ave.speed etc). I use A for the full tank recording and B for individual journeys that I wish to record.
