Maytag PYE2300AY Electric Dryer Logo
Posted on Feb 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Noise the dryer makes a skweeky noise ,thinking about oppenning it and sparay the belts with wd40.is it a good idea??
Anonymous
Level 3:
  • Master 333 Answers
  • Posted on Feb 18, 2009
Anonymous
Master
Level 3:
Answers
333
Questions
Helped
200647
Points
1310
No if you spray the belts with wd 40 the belt will slip and you will have a problem. They have a spray belt dressing made for this type of problem. I hope this helps. Don't forget to rate my answer.
1helpful
Maytag neptune mde6800ayw electric dryer
The tensioner pulley for the belt, oil it with 3 in 1 oil, NOT WD40, if it stops then you need to replace the pulley because it will come back :)
My LG electric dryer is making a noise like it is out of balance but that is not it. I was thinking it may be the belts but my manual does not get that specific. Any ideas?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Mar 20, 2011 • LG Dryers
My brush roller stopped spinning so I had to take it off and clean out all the hair that had gotten wound around it. I replaces it and now it is make a lound noise, but only when the brush is on. Could it...
Could very well be the belt. When cleaning the brush it is a good idea to add some WD40 at the ends where the plastic pieces are that hold the brush in the vacuum. The brush needs to be able to move freely around the plastic pieces. Add the WD40 and rotate the plastic pieces around the brush until they move freely. Reassemble making sure the belt is put in correctly so the brush moves in the right direction.
Please provide a Thumbs Up if this solution is of help to you. Paul
2answers
1helpful
Hoover Maxi 6 TC50 Tumble Dryer making squealing noise
Have you fixed this problem? I also have a Hoover condenser dryer, only a few months old, and has started to make a squeal/whistle. I'm thinking it might be the front fan needing some WD40, OR too much water vapour around the belt that moves the drum causing the sounds.
If it's the fan, lubricating the shaft and its components should fix the problem, if a wet fan then I'd think maybe fully cleaning the condenser filter, reservoir ect will fix the problem.
The problem seems to go away though "mostly" 15 or so minutes after you start the dryer, so that makes me think ones it gets warm something is expanding to allow more "give" so maybe the belt.
2answers
My dryer makes a scweeking noise as it spins
check the motor bearing maybe it needs some lubrication.
Aug 06, 2009 • Dryers
2helpful
Loud squeaking noise
dont spray that on the belt lol that stuff is flamable i think lol you most likely have bad phelt glides  they are pads that sit between the drum and the drum support and when that wears out it squicks or maybe you have a bad idler pulley which is what holds the belt maybe its rusty or something but most likelt its the pads
Dryer makes a skweeky noise
change felt around drum please rate me
7helpful
2answers
KENMORE DRYER
Hello ENRIGHT11 Welcome to Fixya
My name is Huum,
You said,
DRYER MAKES VERY LOUD NOISE WHEN RUNNING. ALTHOUGH IT HEATS UP AND BEGINS TO DRY, IT STOPS RUNNING COMPLETELY AFTER ABOUT 5 MINUTES. IF YOU WAIT AN HOUR, YOU CAN START IT AGAIN, BUT IT AGAIN SOUNDS VERY LOUD (ALMOST A RATTLING SOUND) AND THEN SHUTS OFF AFTER 5 MINUTES
Faulty Blower Wheel
If you hear a great deal of noise coming from the blower area of the dryer when it is running, then the blower wheel could be defective.
The are many different designs for blower wheels and just as many unique failure modes. Vanes (fins) can break off the wheel and bounce around in the blower breaking more pieces. The blower can break around the coupler with the shaft. This can cause the blower to spin loosely on the shaft. The blower can form cracks which cause it to vibrate, etc.
You should also not be surprised to find foreign debris in the blower. The occasional bird, rodent or squirrel has been known to bypass the out vent cover. If they crawl into the exhaust tube the first thing they come into contact with is the blower wheel.
If the blower wheel is not spinning, or if it is missing vanes, it is not moving air efficiently. As a result, heat is not removed from the heat source and it can trip the high limit switch or blow the thermal cut-off.
Worn Belt
A worn belt can stretch and/or become brittle with age. The belt can then slip on the drum or motor to cause squeaking. If this is the case, the solution is to replace the worn belt.
The belt is not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, worn drum glides or worn drum rollers depending on brand and style.
When replacing the Belt is is a good idea to also change the Drum Support Rollers, Drum Glides, Idler Pulley and Clips. All of these items are economical easily changeable when replacing the belt. The upside is that your dryer will operate like new.
Recent Customer Symptoms:
Dryer makes loud noise when turned on. Dryer works and heats up OK but makes too much noise.
Worn Drum Glides
Some dryer models are equipped with Drum Glides. The front of the dryer rests on these glides. They provide a low friction surface on which the drum spins. After time however, this glides wear down. Much like an automobile brakes, these glides make a load grinding noise when they wear thin. This griding against the drum usually leaves a bare metal stripe that is visible at the point of contact. If the glides are worn, the solution is to replace them.
The drum glides not the only items that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, a worn belt or worn drum rollers depending on brand and style.
When replacing the Drum Glides it is a good idea to also change the Drum Support Rollers, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new.
Worn Rear Drum Bearing
Some dryer models are equiped with a Rear Drum Bearing. The rear of the drum rests on this bearing. It provides a low friction surface on which the drum spins. After time however, this bearing will wear down. If the bearing is worn, the solution is to replace it.
The rear drum bearing not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum glides, a worn belt or worn drum rollers depending on brand and style.
When replacing the rear drum bearing it is a good idea to also change the drum glides, drum support rollers, drum belt, idler pulley and clips depending on make and model. All of these items are economical and easily changeable when replacing the rear drum bearing. The upside is that your dryer will operate like new.
Worn Drum Support Rollers
Some dryers such as Whirlpool/Kenmore brands are equipped with Rear Drum Support Rollers. The weight of the dryer drum rests on these rollers. They provide a low friction surface on which the drum spins when in operation. After time however, these rollers wear down. When they wear, often times they begin to elongate and form a non-round 'cam' shape. The result is that when the dryer is turned on it creates a rumble that sounds as though you are trying to dry a pair of tennis shoes. This sound is usually the drum being forced up and down on the non-round wheels. If the rollers are worn, the solution is to replace them.
When replacing the Drum Rollers it is a good idea to also change the Front Drum Glides, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new. Whirlpool
Kenmore models have a dryer maintenance kit that contains all of these items in a single kit.
Thank You For trusting us with your question
Please remember to leave a
solved rating before you leave!
2helpful
2answers
Candy condenser dryer cdc 266
Forget purchasing anything, i had the same problem. Slide the lid back and spary the belt with WD40..... noise goes and works a treat and no money spent!
Justin
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
