GE Advantium SCA1000DWW
sn TA901491K
Door handle broke off of top and bottom posts.
What parts do I order for repair?
Bryan Flanigan
Over the range Microwave to replace the door handle
There is a inner door trim on the inside of the microwave door that can come off to expose the screws for the handle. This trim is held in place by clips built into the trim, ( some older models may also have screws - look for them and remove before going any further ) the tabs on this trim can break easily but with a putty knife and some patience, the trim can be removed to get at the handle screws. Seepicture help. This trim can be pushed so the clips will "pop" back into place after the handle repair.
You must order a handle with the same model.
On some microwaves you might have to replace the whole front door, possibly just the door handle.
parts are available at
http://www.partselect.com/
http://www.repairclinic.com
You can order the required handle parts from www.reapairclinic.com
You can order from part select.
Here is the part: HANDLE, DOOR WH (HNDL DOORWH)
And here the diagram to install it:
PArt 1116 in diagram
