Panasonic N2QAYB000487 Remote Control Logo
G W Grote Posted on Feb 17, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Panasonic N2QAYB000779 The "return" button does not work
Level 3:
Top Expert:
  • Panasonic Master 76,851 Answers
  • Posted on Feb 18, 2013
Panasonic Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15008274
Points
237762
It sounds that the remote control need cleaning. Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to know more about how to test and clean a remote control, check this link.
Panasonic KX-T7633-B Digital Telephone Black 3-Line LCD Proprietary Phone. The boxes go off. What to do
Not sure what you mean by "The boxes go off", it is a phone, not a box.
Return to Panasonic for warranty repair.
https://www.google.com/search?q=kx-T7633
1helpful
How to reset factory stereo panasonic sc-vk825d
Turn the unit off then back to ON. Alternatively, turn the unit off, disconnect the AC power supply cord, and then reconnect it
OR....
While stopped and "DVD/CD" is the source, press and hold [L STOP] on the main unit and[h10] on the remote control until "Initialised" disappears from the television.Turn the unit off and on again. All settings will return to the default values
PANASONIC SA- HT340 CONTINUESLY SWITCHES ON AND OFF WHEN ON DVD/CD MODE BUT WORKS FINE WHEN ON FM/AUX. THE RED LIGHT STAYS RED AND DOES NOT GO GREEN. ANY IDEAS PLEASE
If all else fails try resetting the unit to the initial factory settings.
While stopped and "DVD/CD" is the source, press and hold [Tune=mode/FM-mode Button] on the main unit and [>=10 Button] on the remote control until "Initialized" disappears from the television. Turn the unit off and on again. All settings will return to the default values.
5helpful
2answers
Como programar un control de dish a una tele panasonic
Depende del modelo del control remoto. Pero en general:
Press and hold the desired mode button (about three seconds) until all mode keys light up, then release.
Use the number pad buttons to enter the three-digit number corresponding to the equipment. The light will blink off after each digit is entered and then return to a steady light. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times. To verify the code works, try several functions for that equipment.
Panasonic TV: 508, 509, 510, 511, 512, 566, 574, 575, 628, 644, 651, 662, 663, 668, 672, 673, 676, 685, 687, 689, 698, 697, 700, 706, 714, 716, 234, 247
Panasonic: 008, 009, 010, 011, 012, 066, 074, 075
Display screen shows "Will return soon" Would like
You need to cancel absent message on your phone. The method depends on which Panasonic phone system your phone is connected to. Following are the methods for three different Panasonic phone systems. Once you cancel absent message, your screen should return to date and time, if not then press * until it does.
KX-TA624 Phone System
Press intercom button, dial 750#, lift handset then return handset to cradle to end.
KX-TA1232 Phone System
Press intercom button, dial 7500, lift hanset then return hansdset to cradle to end.
KX-TDA100 or KX-TDA200 Phone Systems
Press intercom button, dial *7500, lift handset then return handset to cradle to end.
I have a Matsui portable TV for which the remote controller does not work. How do I retune the TV
you need to check the buttons on the tv itself and see if you have a menue button or a imput button then go from their to return to whatever mode you are set up to watch tv
1helpful
Need to be able to Unlock Parental Control and set new Password
Turn on the TV, put it on whatever channel you have when you watch a dvd....
While the unit's in STOP mode, hold down the unit's l<< (skip button)
and the STILL\PAUSE button down simultaneously and then the POWER button for longer than 3 seconds (until "Initialized" disappears from the TV monitor) The lock will be released and all initial settings will return to the Factory default values.
good luck to you....let me know if this worked!!!!
mtg
6helpful
DVD Recorder Screen keeps saying HOLD and not switching on
CHILD LOCK:
The Child Lock Deactivates All Buttons On The Unit & Remote Control.
To Deactivate Press & Hold (OK) & (RETURN) Simultaneously Until "X HOLD" Disappears.
7helpful
WHEN I TRY TO USE MY REMOTE CONTROL ON MY PANASONIC VCR/DVD COMBO MODEL #DMR ES35V, THE DISPLAY SHOWS U30 1 AND WON'T WORK THE VCR/DVD. CAN YOU HELP ME?
I called tech support and their answer was simple!
Error Code U30 1.......the fix, press and hold the number one (1) on your remote and at the same time press and hold the ENTER button for 10 seconds while pointing the remote at the units sensor.
Automatically, my unit returned to normal and all my buttons on my remote returned to operational mode!
So, it was confirmed by Vincent at Panasonics tech support, that error codes U30's are rare, but it's a system safety feature. If you were to come across an error U30 2, you would push and hold the number 2 while pressing and holding down the ENTER button....so on and so forth.
I hope this helps someone else out there!
Shelley
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
