HP OfficeJet Pro 1170c InkJet Printer Logo
Posted on Feb 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I unblock cartridge?
Hi, I have an HP Officejet Pro 1170 cse. When I turn printer on I receive message - cartridge blocked, unblock turn printer off then on. I follow the instructions but continue receiving same message. How do I solve this problem?
Anonymous
Level 3:
President:
  • Master 1,902 Answers
  • Posted on Feb 11, 2009
Anonymous
Master
Level 3:
President:
Answers
1902
Questions
0
Helped
902988
Points
6294
Clean the electrical connections rubbing alcohol and a qtip, Also check the ports and try to stick a sewing needle tip in if it will work
HP OfficeJet Pro 6230 not recognizing new cartridges?
HP Printer does not recognize new cartridges due to cartridge problems, cartridges missing or damaged, and a not compatible cartridge with the printer. Now we discuss each step by step how to fix these errors. ·Make sure installed ink cartridges are compatible with your printer ·Open the ink cartridge access door and remove the ink cartridge from the printer ·Clean the removed ink cartridge with a lint-free cloth. Read more steps to fix HP printer ink cartridge error.
3answers
What are the easy ways to Fix HP Officejet Pro 8600 Printer Failure
Well, the printers have always been the most popular choice among consumers as they provide excellent performance and are reliable as well. Wel.l, just like all the other electronic devices, the HP printer is not free from any of the issues. There might be the HP Officejet Pro 8600 Printer Failurewhen you are using the printer of this model.
What are the causes of the HP Officejet Pro 8600 Printer Failure:
The issue of HP Officejet Pro 8600 Printer Failure occurs when there is a print head or an ink cartridge that is not compatible. This is the model of the printer that uses the HP 950 or the 951 ink cartridges. This is also because when you are using a different one, this might lead to errors.
Let us now see how to fix the HP Officejet Pro 8600 Printer Failure:
Reset the printer:
There are times when the printer reset is all that it will take to resolve the HP Officejet Pro 8600 Printer Failure.
Detach the power cable from the printer while the device is switched on.
After that pull the power cable out from the outlet.
Then you need to wait for at least a minute.
After that plug the power cord back into the outlet and the printer.
Then you need to conduct the test print in order to see if the error has been fixed or not.
How to set print alignment in hp officejet K7100
During cartridge alignment, the error message 'Print cartridge alignment failed' displays on the printer control panel....
More Info visit this links...
Print cartridge alignment failed Error Message Displays on the All in...
Alignment Page Does Not Print
Thanks,
HP Printer Support
1helpful
I have an hp officejet pro L7680 printer and am having trouble finding new 88xl cartridges for it. Will the 940xl cartridges work in this printer
You cannot install HP 940 Cartriges for Officejet Pro L7650 as they are not compatible and the mechanism is different for both the cartridges,
In your printer, the HP 88 fits on the left bottom corner of the printer and the HP 940 cartridges are mounted on the Printhead inside the printer on HP Officejet 6500 AIO.
Regards,Suhail
HP officejet Pro 8500. Replaced black/yellow cartridge and still get message "replace ink cartridge" thanks Tim 865-654-1702
Here are some steps can help you.
Use only New Original HP ink
Restart the printer
Rreseat the ink cartridges
Update the firmware, download it from the link, make sure that you choose the correct operating system, and follow the on-screen instruction.
Check the ink levels, click Start , click All Programs, click HP ,click HP Solution Center, click Settings , click Printer Settings , click Printer Toolbox, Click the Estimated Ink Levels tab, note which cartridge is low on or out of ink
Restart the printer.
I hope this will be able to help you resolve the issue.
Thank you for choosing Fixya.
3answers
HP Officejet pro l7580 magenta won't print, new HP cartridge 8/11
You will have to reset the printer.If you want any further support, a technician from techbuddies can help you for free.For this log on to www.techbuddies.org
3helpful
2answers
Error message: "Door Open"
HI there,
Follow the steps below:
Step one: Close the print cartridge access door
1.Verify that the print cartridge access door is completely closed. It may appear to be closed, but if it is not completely closed, the error message will display. Verify that there are no obstructions blocking the door.
2.If you are unsure how to close the print cartridge access door on your model, consult your User Guide for more information.
Figure 1: Examples of closing the print cartridge access door (your model may vary)
f3e57be.gif If you have attempted to completely close the access door and the error still appears, there may be a problem with the door sensor and the unit may require service.
Step two: Service your product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Good Luck!!!
neo
3answers
Supply expired
You can't. Cartridges have a date bomb built in, they may be expired.
Cartridge Blocked
Read HERE to possibly resolve your issue.
Hope that helps...
Geno
k24674
Grand Canyon Tech
Grand Canyon Tech
