Televison & Video Logo
Anonymous Posted on Feb 07, 2013
Apex model #AT2704S front panel buttons stop working? Menu, channels, volume, and power? Also has a red key in lower left corner and the screen is blue. I have tried mute and function buttons on univ
Remedies to get front door panel to allow me to unlock child lock. All buttons will not work!
  • Anonymous Feb 07, 2013
    I do not have the original remote, so I can not get into the menu. And the menu in the front panel is locked. Any other suggestions?
Level 3:
Top Expert:
  • Apex Digital Master 76,851 Answers
  • Posted on Feb 07, 2013
Apex Digital Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15008130
Points
237762
Your Apex TV has been locked by anyway. Just try this method to unlock it.
Apex TVs have parental locks that allow you to block certain programs based on
their rating. When this feature is no longer needed and you want your TV to display all programming no matter its rating, you must unlock your TV. Unlocking your Apex TV is done completely from your remote control and does not require any tools. The process takes less than 5 minutes.
• Press the "Menu" button on the remote control and use the arrow buttons to scroll down to the "Parental Guide" option, then press the "Enter" button.
Type in the default parental code "6688" if you have not set your own code. If you have set your own code, type it in. If you set your own code and forgot it, override it by using "6688."
Use the arrow keys to switch the parental lock to "OFF." This allows all programs to be viewed no matter the rating. Press the "Exit" button on the remote and start watching all your channels.
2 Related Answers
A
Anonymous
  • Posted on Nov 29, 2007
SOURCE: TV lock on
Try this for 2402s
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=71c9242585ab36d831a426f43d10b975&q=Apex+AT2402s
Anonymous
  • 6487 Answers
  • Posted on Jul 20, 2008
SOURCE: unlock apex tv model # AT2702
  • If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired.
  • If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or reset any preset rating levels.
  • If you have a GT2011J or GT2011S Television, hold the (Display) button for 10 seconds, it will unlock the screen. If password or code is requested, try 3308 or 6688.
Hope that helps..........
Apex model PF3225, The TV is Locked (blue screen with red key on the bottom left corner). Don't have original remote...please help
4helpful
4answers
Unlock apex tv model # AT2702
My four year old was messing witht he bottons on the front of my Apex AT2702 television set, and not all it shows is a blue screen with a key symbol in the bottom left hand corner.
Hi
There are 7 buttons with its front panel including power ON/OFF switch button.They are; From left to right:- Video, Menu, Volume(-ve), Volume(+ve), Channel(-ve) and Channel(+ve). If these buttons are not there, it will be difficult to operate this set without a remote control. If you haven't the remote contro with you now, buy one universal remote control. The universal remote control suited for this set is COMCAST ON DEMAND CUSTOM-3 UNIVERSAL REMOTE control. The setup codes are:-
0748, 0765, 0767
OK.
I'm unable to get a picture or sound due to a "key" lock appears in the lower left hand corner of the screen. It will not allow me to unlock it.
Hello
Your TV is locked. Do the following to unlock it.
Apex TVs use a four digit code to control the v-chip. The override code for many models is 6688. Other sets may not have one, or may have a default code of 1225 instead of an override code.
  1. To use the override code:
  2. Hit the MENU key to get to the menus.
  3. Go down to the SYSTEM menu and hit the right arrow on the remote control.
  4. Once in the SYSTEM menu, go to PARENTAL GUIDE. It will ask for your code.
  5. Enter the override code listed above. From here, you can turn on and off different rating restrictions, as well as set a new code.
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desiredOK.
Hello I am seeing a blue screen and a lock on the bottom left corner. I am unable to change channels or input. Please advise.
Hello
Your Apex Tv is locked. You must unlock it and reset all the V-chip settings once more. To unlock it do the following.
OK.
3helpful
I have an apex tv that has a lock(key symbol) on the lower left corner of the screen. The tv seems to be locked how can I unlock it? I using a phillips universal remote.
Hello
Just try the following to unlock your Apex TV.
OK.
TV has no vision , only one channel has sound
your tv is locked!
If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired. • If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or reset any preset rating levels. • If you have a GT2011J or GT2011S Television, hold the (Display) button for 10 seconds, it will unlock the screen. If password or code is requested, try 3308 or 6688.
http://vchip.atspace.com
4answers
TV lock on
If you have the remote, hold down the (F) function key and press mute. If you need a remote, go to
http://www.electronicadventure.us/Merchant2/merchant.mv?screen=prod&store_code=EA&product_code=8201800032L
Top Apex Digital Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
