Apex Digital PF3225 32" TV Logo
Question about Apex Digital PF3225 32" TV
Apex model PF3225, The TV is Locked (blue screen with red key on the bottom left corner). Don't have original remote...please help
My TV has a blue screen with a red key in the bottom left corner. I don't have the original remote. Please help. What can I do??
Posted by Sharon Logsdon on
    Top Expert:
  • Apex Digital Master
  • 76,851 Answers
Press the "Menu" button on the remote control and use the arrow buttons to scroll down to the "Parental Guide" option, then press the "Enter" button.
Type in the default parental code "6688" if you have not set your own code. If you have set your own code, type it in. If you set your own code and forgot it, override it by using "6688."
Use the arrow keys to switch the parental lock to "OFF." This allows all programs to be viewed no matter the rating. Press the "Exit" button on the remote and start watching all your channels
Posted on Mar 23, 2012
5 Related Answers
Anonymous
SOURCE: Apex TV locked out picture
  • If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired.
  • If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or reset any preset rating levels.
  • If you have a GT2011J or GT2011S Television, hold the (Display) button for 10 seconds, it will unlock the screen. If password or code is requested, try 3308 or 6688.
Posted on Apr 28, 2008
Anonymous
  • 319 Answers
SOURCE: unlock apex tv model # AT2702
Please try this:
On the remote hold down the (F) function key and press mute.
Posted on Jul 20, 2008
Anonymous
SOURCE: my apex tv is locked.
You have to hold the button that looks like a flag (top left) and press either the mute or video button. I don't remember which one
Posted on Nov 13, 2008
Anonymous
  • 346 Answers
SOURCE: KLH TV LOCKED
press and hold menue button on the tv, for more than 10 seconds to unlock
Posted on Dec 02, 2008
Mike Meder
  • 259 Answers
SOURCE: APEX tv model #AT1302 My tv screen is black with a
child lock is active. Unlock press function and then mute on remote. only way to do it.
Posted on Jan 08, 2010
2answers
4helpful
4answers
Unlock apex tv model # AT2702
Hope that helps..........
Unlock Tv
Please view this FixYa Tip which outlines the procedure for removing the parental lock when the screen is locked on the Apex TV.
Thanks for using FixYa
1helpful
Locked tv
I'm having the same problem. My screen is blue with a red lock in the bottom left hand corner. None of the buttons work except the on/off button on the television.
Locked tv
Try pressing the ( F ) button and the mute button at the same time on your remote control.
Here's the link for the 2402s manual:
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=4db1185db9d3369
hope this may help;
33helpful
4answers
My apex tv is locked.
2answers
Locked tv
MY TV IS LOCKED CANNOT GET IT TO TURN ON HELP!!!!!
3answers
Accidently locked tv
gonk,
Sorry but you're going to have to be a bit more specific than that.. What kind of Tv is it, what model number, is it the original remote, do you have an otherwise good pic and sound, do functions (vol, ch, power) on the Tv work???
Bill
2helpful
2answers
My TV is completly locked up
You need a APEX remote to unlock the parental controls. You and go to there web site to get the ording info and he preocedure to unlock the tv. www.apexdigitalinc.com
Open Questions:
0answers
Whirlpool Side by Side American style Fridge Freezer too hot and too cold! I have model S20D FSS10-A/D Service number 8586 161 15000 Side By side FF - and after replacing many components on the rear board 13 years ago it has been running well. However.... with a new fault I am hoping that the symptoms may allow someone to point me in the right direction. Not having a circuit diagram has been a hindrance. Over last few years the front panel inside in the fridge in my model has been developing a display fault - it started with the LED display winking out briefly about twice a second. The mark/space of time for the 'winking out' changed slowly to 50% on 50% off twice a second to eventually become just flashing on briefly twice a second and finally off all the time. However, the default settings/functioning of the FF has been working fine so didn't need to use the panel. However, can't read any fault codes that might be there I don't think that the buttons are doing anything on the panel. It has 15v supply but I don't know what supply voltage from the rear PCB should be. Then... A few weeks ago the house RCD tripped once and the fridge bulb had blown ********* stain on bulb interior and Relay RL3 was chattering randomly - I took the board out and noticed a fried circuit track where it looped thinly either side of component hole that was unused. I soldered in a bridge over the gap. Restarted the FF. From then the freezer cools to -32c and warms up to -2c and down to -32 etc.. The fridge varies in temp but does go as low as 0c and high as +9c. Alongside this, when the compressor is not running we can heard a ticking noise and identified that the compressor fan was turning slowly about ?100 rpm There's no ice build up, the freezer to fridge air louvres are opening and closing when you switch the FF on, and do seem to open and close at different times. The evapourator fan seems fine as does the compressor fan, the bottom of the fridge is dust free and the rear panels are all on to allow proper cooling of the condensor motor. I pulled the board again, checked all the capacitors I have a slightly different board to many and all the capacitors I had used from one brand have failed again. I took all the caps out and measured them. C6, C16 should have been 0.68uF and were in the order of a few nF C14, 26, 27,28 should have been 0.1uF and were 0,.6nF, 2nF, 10nF and 38nF respectively. All other film and electrolytic capacitors were within tolerance. I replaced all the faulty caps thinking that I had found the display problem because you had told me in the past that C6 and C16 relate to the front panel and the cooling issues and fan issues but NONE had been cured :- I checked the continuity to the front panel of all connectiions and they're fine. Also checked the 2 electrolytics on the front board. So I am at a bit of a loss. I have checked the zener diodes in situ and all have about 6v forward voltage drop I cannot find a replacement board due to different connectors on my unit - so unless I can fix we will have to fork out for a new FF :-
See all Apex Digital PF3225 32" TV Questions
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
