The short answer is yes.
They are dangerous because they shoot heavy projectiles at a minimum of
40 miles per hour. If you are using a
pitching machine, it is imperative that you wear the proper protective gear
such as helmet, chest and leg guards.
Yes, a high-pitched squeal coming from your electric snow blower when you turn on the blower could indicate a bearing issue. The blower motor is typically equipped with bearings to reduce friction and allow the motor to run smoothly. Over time, these bearings can wear out or become damaged, resulting in a squealing or grinding noise.
If you suspect a bearing issue, it's important to have your snow blower inspected and repaired by a qualified technician or service center. Attempting to repair the snow blower on your own could be dangerous and may cause further damage to the machine.
Question edited for a lot more clarity. It is actually a 'Pitching Machine', rather than a 'batting machine'.
They do different types, but moved to Atec Baseball category.
Use two drops of light machine oil like 3inOne on the pitching wheel spindles and any other rotating parts like the motor shaft.
That is probably the flyback transformer and may be dangerous to service by yourself. Get a pro to look at it and stay safe. Voltages inside TV sets can exceed 10,000 volts AC.
Have you contacted Iron Mike yet. Most small a/c motors only go in one direction. Need more info. Was it was working correctly, then changed? Or did you buy it used this way? If the machine is NOT turned off in the correct position, then restarted quickly, it will run backwards and jam up the chain. You may need a new motor. email me if needed, Steve Manookian Pitching machine repair, Los Angeles area, [email protected]
Sounds like many small problems. Have you contacted Iron Mike yet. Need more info. Was it was working correctly, then changed? Or did you buy it used this way?
