Question about Jugs Small Ball Pitching Machine
Jugs Jr Pitching Machine. Keeps blowing the fuse. Checked motor with 12 volt battery work good. Disconnected motor from circuit card, still blows fuse.
Posted by jdmn4 on
Raul Carrion
    New Friend:
    Problem Solver:
  • 18 Answers
Look for stripped wires that could be your problem if you find any tape them up with electrical tape
Posted on Jan 21, 2015
1 Related Answer
Finn
  • 60 Answers
SOURCE: my jugs pitching machine is making a rattling
It could possibly be one of the bearings starting to go, is the machine well used or new?
Posted on Nov 05, 2010
Hat is the max speed for a Jugs MVP
I think it's 70 mph not positive but pretty sure
May 06, 2014 | Jugs Mvp Pitching Machine
Blowing fuse on small ball pitching machine
Are you using the right size fuse I would call jugs and ask them what fuse it takes you could also have a wire that's exposed and touching something metal look for that too
Mar 09, 2014 | Jugs Small Ball Pitching Machine
Replacement Legs
1 1/4 pipe from home depot 24 inches long 30 degree bend 4 inched down
Feb 02, 2014 | Jugs Small Ball Pitching Machine
I have a jugs jr pitching machine and can't get the speed to adjust
Take off the cover and make sure the wire is connected to the knob and check the wire maybe it's exposed an not working properly
Mar 03, 2013 | Jugs Small Ball Pitching Machine
Jugs 101 pitching machine , bottom motor will not run ,no current at connector on circuit board
Just had this happen on my machine. Opened up the control box and found center disc capcitor was loose from cold solder joint. However we also found the hot lead for the motor at the wiring block on the circuit board had a cracked solder joint. Simply reheated with solder iron and applied little extra solder and it working again.
Jul 21, 2011 | Jugs Baseball 101 Pitching Machine
I have checked the wind shield wipers motor to try to find out what is shorting out the fuse. Where could the short be located that is causing the wiper fuse to blow?
You need to isolate the problem by disconnecting the windshield wiper motor. If the fuse does not blow with the wiper motor disconnected the problem is in the windshield wiper motor. If the fuse still blows with the motor disconnected, there is a 12 volt wire shorted to the frame. You will most likely need a set of wiring schematics to trace down the short.
Mar 21, 2011 | Hyundai Accent Cars & Trucks
My jugs pitching machine is making a rattling noice in the motor area
Oct 27, 2010 | Jugs Small Ball Pitching Machine
DeWalk DC500 wet/dry vaccum doesn't work
Vacuum works with the battery but does not work with 120 volt. Every time I plug it in it blows the internal fuse. I have replaced the fuse inside the vaccum several times and every time i plug it in it blows. What do you think it could be?
Feb 21, 2009 | Dewalt DC500 Canister Wet/Dry Vacuum
Jugs Small Ball Pitching Machine Logo
2,449 people viewed this question
Top Jugs Baseball & Softball Experts
Kardoc
NOEL
NOEL
Ned Halaweh
Ned Halaweh
Are you a Jugs Baseball and Softball Expert? Answer questions, earn points and help others
