Question about Jugs Small Ball Pitching Machine
Fix jugs pitching machine wheel - Jugs Small Ball Pitching Machine
victorleo
    New Friend:
  • 7 Answers
There are different jugs pitching machine,Please give brief description.and tell us what exactly wrong happen with it.
Posted on Feb 05, 2015
Raul Carrion
    New Friend:
    Problem Solver:
  • 18 Answers
What's wrong with it need more info
Posted on Jan 21, 2015
1 Related Answer
Finn
  • 60 Answers
SOURCE: my jugs pitching machine is making a rattling
It could possibly be one of the bearings starting to go, is the machine well used or new?
Posted on Nov 05, 2010
Hat is the max speed for a Jugs MVP
I think it's 70 mph not positive but pretty sure
May 06, 2014 | Jugs Mvp Pitching Machine
How to remove wheel from jugs pitching machine
Pretty sure you can take it to a tire shop and get that done
Apr 02, 2014 | Jugs Small Ball Pitching Machine
Blowing fuse on small ball pitching machine
Are you using the right size fuse I would call jugs and ask them what fuse it takes you could also have a wire that's exposed and touching something metal look for that too
Mar 09, 2014 | Jugs Small Ball Pitching Machine
I have a 2 wheel combo pitcher and when i drop the ball into the shoot it just bobbles around.It will not throw it
You most likely need to use medium grade sandpaper and use it one the tires. They need to be sanded down in order for the machine to shoot the balls out.
Jun 04, 2011 | Jugs Small Ball Pitching Machine
When in operation the machine itself is out of balance.
pull off the wheel and run the machine. you will be able to see if the hub is out off balance. if it spins true the you have a rim or tire out. this can be fixed by having a tire shop balance it for you or call Jugs and get a complete replacement,tire and rim ,shipped mounted and balanced.
it is very unlikely that the motor shaft is damaged unless it was droped trying to load it into a truck.
it most like;y is the tire and rim that is out
Nov 29, 2010 | Jugs Small Ball Pitching Machine
My jugs pitching machine is making a rattling noice in the motor area
Oct 27, 2010 | Jugs Small Ball Pitching Machine
Jugs Small Ball Pitching Machine Logo
1,560 people viewed this question
Top Jugs Baseball & Softball Experts
Kardoc
NOEL
NOEL
Ned Halaweh
Ned Halaweh
Are you a Jugs Baseball and Softball Expert? Answer questions, earn points and help others
