Question about Jugs Lite-Flite Baseball/Softball Machine
Can someone tell me how to replace the fuse. One week old machine and power stopped. Thanks
Posted by J Cline on
  • Tony Rizzo Mar 16, 2017
    The fuse is hard to get to wire external fuse holder
Tony Rizzo
    New Friend:
Fuse is in control ..Hard to get to I cut the section of the box out to get to fuse figured its going to blow often i was cleaning the wheel with a wet sponge when my fuse blew first week.
Posted on Mar 06, 2017
I have a F&P washing machine Smart drive 603 about 10 years old, that has stopped working. No power, no lights, I am guessing electrics. Is it worth fixing? Not sure if it is terminal or not!
Ten years is a lifetime to a washing machine. If the total cost of repairs equals 50 percent of the cost of a new machine, the old one should be replaced.
Jul 12, 2016 | Washing Machines
My power window and door locks fuse keeps blowing.
When the fuse blows figure out what you are doing, what switch is being pressed, then remove the needed panels to access the wiring to the switch and motor it operates, then you will find the damaged wiring and repair the short, no quick fix, just hard grunt work.
Mar 16, 2017 | 1996 Toyota 4Runner
Indesit WIAL143 got no power
Could possibly have damaged the cable, have you got power across live and neutral to the washer.
Apr 17, 2012 | Indesit Washing Machines
My new bosch logixx front loader washing machine (3 weeks old) is showing a flashing error code F:43....what does this mean ? Thanks
I just realised that I don't appear to have a comprehensive list of Bosch error codes, but some quick research tells me that F43 is a motor error, usually associated with the motor brushes requiring replacement (Though they may also be sticking and just require removing, cleaning and re-fitting).
Jun 30, 2011 | Washing Machines
Hi I have a wd640 hotpoint aquarius washer/dryer that has stopped working and been told by a fixya pro that it was the main circuit board,and so ordered this assuming it was the circuit board behind the...
hello there is usually a power board sits at the bottom if the machine is dead there a glass fuse that blows just replace the fuse make sure you use the same rated fuse the value will be on the end of the fuse hope it helps
regards
shaun
Mar 20, 2011 | Hotpoint Aquarius WD640 Front Load...
Uniden PowerMax 5.8 no audio transmission on two of three remotes
If phone is more than 1 yr. old, battery needs to be replaced, if not reset base by disconnecting power, pressing and holding delete key while reconnecting power.
Mar 07, 2009 | Uniden TRU8885 Digital Answering Machine
I have no power to the the radio
You will have to chase your power wire back to the fuse panel and/or the battery itself. The burning smell was more then likely the main power cord burning up. Replace it and it should all work well.
Dec 16, 2008 | 1992 Honda Accord
Jugs Lite-Flite Baseball/Softball Machine Logo
2,391 people viewed this question
Top Jugs Baseball & Softball Experts
Kardoc
NOEL
NOEL
Ned Halaweh
Ned Halaweh
Are you a Jugs Baseball and Softball Expert? Answer questions, earn points and help others
