The heating has been fine for two years - then the boiler would not ignite if both the hot water and the central heating were to come on together, they both work fine individually. I had a plumber look at the boiler and he said the boiler was fine but I needed a new programmer. I have replaced the programmer with the same model, as i was told I could leave the back plate on - and still it does not work - any ideas
What size of gas line is going into boiler and water heater? is it black iron ? natural gas or propane? have you checked gas pressure at water heater and furnace ? if they work fine individually then you have a problem with incoming gas pressure. Call gas company and ask them if they would come out and check gas pressure.
hi could you give me boiler details make/model and programmer model/make , it sound like there is a link missing in the boiler control panel ? or programmer base is wired incorrect ? some have links in which need moving or not ?
