Moved into a new apartment. The boiler heats water just fine, no problems. Have not used heating as it has been warm. Boiler has been set to summer mode. When I set to winter mode, I expect heating to kick in. It does not light. It did briefly last night after I played around with it, turning off the hot water heating. This should have left it in central heating mode only, however it failed to stay on more than a minute. Currently, it is in summer mode, hot water heating only. It is a new boiler. The gas supply was cut off externally a few weeks ago for a few hours to facilitate other people's supply in other apartments. No hot water problems since. It is connected to a Honeywell thermostat which is set to AUTO. Hoping someone can help!
SOURCE: gas central heating boiler. insuffient water pressure.
u need to have a key (its like a T shape key) and u put that under the boiler its a hole in there, than u open the tap which is near this hole.
SOURCE: Combi Boiler - Running warm & then cold!? HELP!
the problem was solved on my system by replacing thermostatic valve on shower and putting non return valves on hot and cold feed to shower . the problem was caused by cold water getting into the hot water line through the shower hope this helps
SOURCE: hot water boiler will not ignite
Check all your limit switches on this unit. One of them is either tripped or bad.
SOURCE: alpha 240e boiler wont fire up for hot water, will for heating
most likely the diverter valve.. when hot tap turned on the movement of the water through the valve operates a diaphragm which pushes a pin/button//switch to tell the boiler to fire up
It's a Immergas victrix zeus condenser boiler. 32kw
